Removing Glue/residue w/out damaging anodising on chassis
General info, Q&A.
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
Hi guys - i've just recieved a very nice original RC10 off US ebay, i'm really pleased with it (especially considering what I paid) It looks virtually new.... with only enough tell-tale scratches on the u/side of the chassis to suggest one or two runs :)
Thing is some velcro strips have been stuck to the inside of the chassis (presumably to hold in the battery :? ) On removing these strips it has left the glue residue behind that has gone hard over the years
Does anyone have experience of successfully removing such residue without damaging the gold anodising beneath? I was thinking of using hot water to soften the glue & then lighter fluid to finally remove it?
aconsola
Re: Removing Glue/residue w/out damaging anodising on chassis
Post by aconsola »
I've used goo gone, or acetone with good results.
yeah, pretty much, acetone, or wd40 works for most adhesives on tapes/velcro, etc. Acetone breaks down crazy glue residue.
Brat
Post by Brat »
To remove sticky glue residue from masking tape, double sided tape etc the best is Turpentine. Nothing beat it. Best of all, it will neither harm the chassis nor nylon parts. As for super glue, Acetone is the best. Hope these help. :mrgreen:
My collections:
Nikko Brat, Nikko Dictator II, Nikko Thunder Eagle, Kyosho Pure Ten Nitro, Associated RC10, Associated RC10T, Associated RC10 Graphite, Associated B4, Tamiya Tamtech 1/24 Porsche 962C, Tamiya Striker, Tamiya TRF 501X WCE.
DerbyDan
Post by DerbyDan »
Well it looks like Acetone is the stuff to use.... thanks guys
Now trying to find some in these health & safety concious times could be another matter :roll:
Edit; Actually seems quite easy to get hold of - a quick Google brings up UK suppliers easy enough :)
mikedealer
Post by mikedealer »
acetone should be available at any paint store and its nasty shtuff. wear chemical gloves (usually the blue latex ones) and dont breath that stuff in too long. if you drop plastic parts into a bucket of it, after a bit of time the part will turn into a goopy mess.
Brandon G
Post by Brandon G »
I always liked lighter fluid. Usually comes in an easy to squirt container. Dries w/no residue.
mikedealer
i use the goo remover stuff that comes in the lighter fluid type can from home depot, goo something. not the citrus one but the one that burns like a mofo if you get it on your skin lol. melts plastic too and discolors lexan after 2 seconds! lol
budhatrain
Post by budhatrain »
denatured alcohol- I picked it up from the local hardware shop. I have been using it for nitro stuff. found out it takes tree sap off of real cars without damaging paint etc. use it around the house for sticky residue from stickers and such. Safest, cleanest and cheapest stuff out there. I used in a hand spray bottle.
Plus I used to to clean all my M.A.S.K. stuff I bought on ebay
SteveK
Post by SteveK »
budhatrain wrote:denatured alcohol- I picked it up from the local hardware shop. I have been using it for nitro stuff. found out it takes tree sap off of real cars without damaging paint etc. use it around the house for sticky residue from stickers and such. Safest, cleanest and cheapest stuff out there. I used in a hand spray bottle.
I have been looking for something to peel the paper-based stickers off some plastic RC bodies, I will have to give denatured alcohol a try. 91% isopropyl alcohol does nothing, and I'm hesitant to try anything harsh on them unless it's a last resort.
A columnist in RCCA talked about using lighter fluid as cleaner for years, and then a reader wrote a letter telling him what an idiot he was and how dangerous the stuff can be. Whatever you use, wear gloves and do it someplace very well ventilated. A cartridge respirator is a good idea as well.
Has thanked: 357 times
Been thanked: 470 times
Nitro fuel will do the trick on the stickers, and won't hurt the lexan---------but then it's really no better than lighter fluid :?
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Post by LowClassCC »
goo gone won hurt lexan. its pretty much the only thing i use to get the residue off of bodies, chassis' and other various items. but there are always times when stuff is stubborn and it has to be soaked in goo gone a little bit. that's mostly on vintage goo though. :lol:
littleVETTE
Has thanked: 6 times
Been thanked: 10 times
Post by littleVETTE »
lacquer thinner and a little elbow grease. doesn't leave any type of residue or smell afterwards. put some on a rag and go at it. takes off all types of double sided tape, electrical tape, and any other type of tapes. doesn't mess with the anodizing at all. just make sure you do it in a WELL ventilated area, or going you're feel a little loopy after a while.
limestang
Has thanked: 100 times
Been thanked: 249 times
Post by limestang »
I have a really good solution to this problem that does not cause any damage to the surface. For almost any type of tape residue, apply rubber cement, wait a minute and then rub off. Also works well on the tough to remove double sided tape leftovers. Give it a try, you will be surprised how well this works.
- Limestang
Been thanked: 3919 times
limestang wrote:I have a really good solution to this problem that does not cause any damage to the surface. For almost any type of tape residue, apply rubber cement, wait a minute and then rub off. Also works well on the tough to remove double sided tape leftovers. Give it a try, you will be surprised how well this works.
- Limestang
Interesting! I will have to give it a try. I gave up rubber cement when they took the good vapors out of it LOL!
Users browsing this forum: No User AvatarTbot [Bot] and 5 guests
