removing crazy glue from tires without ruining them?????
Hey Guys,
I have a set of losi tires that look practically brand new, but the glue job was pretty poor. I don't know the model of the tire, but it looks like a short step pin stubby stock kit type tire.
normally, I wouldn't care about extra glue, but it looks like the tire wasn't properly fitted to the wheel while it was glued, so the bead isn't flat and won't mount to a rim cleanly. the glue is in pretty thick sections, i could take a really long time and chip and grind it off i suppose, but I'm hoping to maybe dissolve it a little easier, at least the really thick sections.
I have some crazy glue remover, and acetone, does this stuff ruin the rubber? I'm not sure, and was hoping someone who had experience could let me know before i potentially ruin the tires.
I've heard people microwaving tires and wheels to remove the rubber, but does that damage the rubber in the process?
I'm thinking I should be OK, and I think I should know this, but I'm just not sure.
thanks!
thanks!
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
Re: removing crazy glue from tires without ruining them?????
http://www.rc10talk.com/viewtopic.php?f=38&t=13209
http://www.rc10talk.com/viewtopic.php?f=32&t=7513
I think someone may specifically refer to the Losi rubber in one of these..
thanks man! I'll try the oven trick first.....then if that doesn't work, go with the acetone trick.....
- MOmo
I haven't used it yet, but there is UN-Cure available and I have some, just haven't had the courage to try it yet.
MOmo
MOmo
well, i forgot to add my final results to this thread.......but here is what i did.....
i placed the tire in some boiling water for a few minutes.....afterwards, i cooled it off just enough to try picking at the glue. This didn't do too much. So since I was right there in the kitchen, I popped it in the freezer, for maybe a couple hours.....
this made the glue turn kind of white and brittle. I was able to scratch off some of the thin stuff on the sidewall, but the thick chunks were still no go.
I have some CA debonder, which was kind of a pinkish gel, so i started rubbing it onto the glue chunks, and into all the cracks.
this kind of softened the glue, but at this point, I was able to use a sharp xacto, and scrape and pick at the glue until some of it started to come off. The glue was in the bead, so I was able to kind of split the glue away from the rubber, taking off a slight shave of the rubber with the glue chunks. the acetone in the debonder basically made the seam between the glue and rubber easier to find, and I was able to slice between them with the xacto blade.
so the tire is usable now, the bead got a little soft and larger, but it appears to be acceptable now. definitely for a runner type application now, but the tires didn't cost me anything but a little time and debonder.
- rc10johnny
Hey Joe,I'm feelin yer pain,I have some mismatched tires/wheels tryin to split the wheels/tires OFF . I'm tryin Todd's way .they have been in the sink 2 days 2 words NO JOY Oh well!!! lets see what to do next,not like I don't have lots a time
JohnnySr
I would say try freezing them for a good long day or so.....the cold temp is supposed to make the glue brittle and help to debond it. I know after I had it in the freezer, the thin stuff was easily scratched (mostly) off. the rubber will also change diameter at a different rate than the wheels, and that might help.
- rc10johnny
Hey Joe, well I got a new can of acet, man I went everywhere,are people drinkin that stuff. any way I got the tires off. this stuff must be that yella stuff we call gorilla snot ! If I cant wipe it off i'm gonna try the FREEZER being the end of the month PLENTY A ROOM
Johnny
- rc10johnny
- 1825 Views
- 21795 Views
Last post by 328isjohn
- 3276 Views
Last post by Jim85IROC
- 860 Views
Last post by RedScampi
- 2568 Views
- 20 Replies
- 2239 Views
Last post by davidka
- 2169 Views
- 2829 Views
Last post by Winger
