Removing paint from Associated's nylon wheels?
Guys, I have some old front RC10 rims that are painted. I want to strip the paint and dye them. What can I use to strip the paint that won't hurt the nylon? Any suggestions?
Thanks
Matt
Thanks
Matt
- JPAE07
Re: Removing paint from Associated's nylon wheels?
Trying using lacquer thinner, nail polish remover on the inside of the wheel to test. CA glue remover works well too. Might get a little expensive since it only comes in small bottles. Got all the paint off a world car chassis w/o damaging the anodize. Not sure how is on plastic but it should be okay. Just make sure to test it first.
- SmallScaleSmitty
I've heard of guys using Super Clean to strip paint off of Lexan bodies and I don't think that would harm nylon.
I just used Citra-strip and it worked perfectly! Smells much better than the other options. I did a set of 10T wheels painted spray paint. The stripper dissolved the paint without any damage to the wheel.
I also striped a set of rally weapon wheels that seem to be a different plastic painted with what looks like Pactra (the body was painted the same). Took a couple coats and some scrubbing but came off with no damage.
Also known as acetone which comes in large bottles at hardware stores cheapJPAE07 wrote:nail polish remover on the inside of the wheel to test. CA glue remover works well too. Might get a little expensive since it only comes in small bottles.
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
to remove chrome plating from wheels people have used oven cleaner or draino (i have never tried these methods cause i like my chrome lol). removing superglue people boil them or use acetone. i would give one of these methods a shot. i have also used brake cleaner to clean nylon parts without any problems. brake cleaner will also peel paint.
any chemical method i would test out on a unpainted scrap piece of nylon before i would try it on the wheels that you are planning to reuse.
- 22 Replies
- 3737 Views
Last post by Lowgear
- 788 Views
Last post by Der Kommissar
- 1480 Views
Last post by 59burst
- 3442 Views
Last post by mattxb
- 2036 Views
Last post by Winger
- 674 Views
Last post by templeofspeed
- 2827 Views
Last post by Winger
- 2175 Views
Last post by R6cowboy
Users browsing this forum: Tbot [Bot] and 6 guests
