Re-Re 6-gear transmission questions
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
Hey guys...I know this may sound weird, but I've never owned a six gear transmission. All of my builds have either been a stealth or a variation. Anyways, I have a few questions:
1) The spur gear seems to have a little play, like a hair of left/right movement which could introduce some wobble if it's not set fully to the left or right. Is this normal?
2) The right gear on the topshaft is press fit onto the left half of the diff assembly. Really?!?!
3) Lastly, damn is that allen wrench for the idler gears tiny! What size is it?
- Has thanked: 36 times
- Been thanked: 1319 times
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Re-Re 6-gear transmission questions
1) it's basically like a pan car diff, the gear will wobble but will center itself when running
2) yup! With all the cool ball bearing supported inner hubs and thorp gears that was still the way they all were. Just try getting them apart once they are locked down
3) there were better drivers for those .035 bitd, haven't seen one in years. Go slow and they will be fine. People that try to rush it and don't have the Allen fully seated will be unhappy
- RichieRich
Ok, thanks guys. I was concerned I was moving into crazy town.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
you moving from LA to OC?
I'm glad you asked. I build my trans the other night and noticed the spur had some wobble and took it apart to make sure I seated everything right. Good to know (I guess) that it's normal.RichieRich wrote:Ok, thanks guys. I was concerned I was moving into crazy town.
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
- RichieRich
LA to Fontana...um no.JK Racing wrote:you moving from LA to OC?
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
btw... if you check a stealth diff... there is some wobble too (although less)... with a ball diff it's simply impossible not to have any, otherwise it can't diff
- RichieRich
Yes, I went back and checked. But you're right, without a little space, it would be a spool.Lonestar wrote:btw... if you check a stealth diff... there is some wobble too (although less)... with a ball diff it's simply impossible not to have any, otherwise it can't diff
- Been thanked: 12 times
http://www.integy.com/st_prod.html?p_prodid=5986&p_catid=161#.UmHq8iTkYqQ
0.9mm
and if you want the warm fuzzy vintage feel, you can spend more and get the thorp/MIP driver:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXWRS6&P=7
- RichieRich
So the going rate for warm and fuzzy is 3 times more expensive? Probably organic too.
For anything other than those tiny idler gear screws I would stay as far away from Integy drivers as possible. They will round off very quickly, not worth the savings.
- abailey21
I had a complete set of EDS drivers that came with a .035, incidently its the only one that was worth a crap in a the whole package. I had almost $200 in matching drivers and it's the only one left with a good tip
- 1252 Views
Last post by mc10ce
- 3726 Views
- 2929 Views
Last post by askbob
- 698 Views
Last post by Westcoast10z
- 1004 Views
Last post by teman
- 689 Views
Last post by DMAT
- 332 Views
Last post by Frankentruck
- 408 Views
