To wing or not to wing?
sneako43
Post by sneako43 »
Is a wing necessary for a buggy that is not going to be raced? My "low buck build" will most likely never see a proper track.
Thanks.
SC10 -- FT B4.1
ThomasH
Re: To wing or not to wing?
Post by ThomasH »
I will work with out one so up to you really.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
I would if you did high speed runs on an oval but I haven't ever noticed a need on an offroad without any long runs but thats just my $.02.
m_vice
Post by m_vice »
I think it is a must for racing, there are a lot of advantages to it and depending on the wing and the angle you adjust it you get different performance qualities with the car.
not really needed for bashing, but I do think it helps on jumps if you bashing include jumping.
:D
sneako43
Post by sneako43 »
Thanks for the input guys. I'm not planning on running one.
Just in case I do in the future, I have been searching for wing mount tubes with no luck....is there another solution / hardware store fix?
SC10 -- FT B4.1
m_vice
Post by m_vice »
you can get aluminum tube and cut them.
rctenracer
Been thanked: 81 times
Post by rctenracer »
Lowgear
Has thanked: 121 times
Been thanked: 795 times
Post by Lowgear »
Ain't no thing but a chicken wing.
sneako43
Post by sneako43 »
Thanks for the info...just need to get that size tube and I'm set.
SC10 -- FT B4.1
sneako43
Post by sneako43 »
What is the length of the tube originally offered by AE?
SC10 -- FT B4.1
greene-r74
Post by greene-r74 »
Wing it
shirochanwrx
Post by shirochanwrx »
I don't know, man.
At low speeds, the wing doesn't matter.
At high speeds, if done properly, the wing can add stability and rear traction (and therefore braking) at the expense of top-end speed (gotta get that downforce from somewhere). If the wing is providing downforce over the rear axle, it is decreasing high-speed steering response, which in most cases is good.
At high speeds, if done improperly, the wing can cause undue loss of top-end speed and can severely decrease steering. For example:
bad spoiler.jpg (21.29 KiB) Viewed 1499 times
This probably doesn't work too well.
Lowgear
Post by Lowgear »
Bosozoku !!!
transamman908
Post by transamman908 »
I like the double decker wings myself
WTF Spoiler.jpg (43.55 KiB) Viewed 1489 times
dsmith
Post by dsmith »
it gotta increase your top speed 8)
Users browsing this forum: No User AvatarAmazon [Bot], No User AvatarBing [Bot] and 4 guests
