Installation guide & tips: Optima belt conversion
Hi guys, I need some of your expertise. I received a belt setup for my Project CYANide Optima. It looks like I have the 2 diffs with belt sprockets, a couple belts and the rear gearbox halves, and a little plastic roller gear. I have no instructions on how to install the belt drive. I could probably figure it out, but an installation guide or pictures of someone's setup would be very helpful. Thanks in advance!
ROH73
Been thanked: 23 times
Re: Installation guide & tips: Optima belt conversion
Post by ROH73 »
Check out this thread from a couple months ago:
http://www.rc10talk.com/viewtopic.php?f=30&t=17279
Regards,
Robert
Thanks, ROH73...I knew I'd seen that guide somewhere on here before--imagine my surprise to learn it was in response to my own topic! :oops:
Lowgear
Has thanked: 121 times
Been thanked: 795 times
Post by Lowgear »
Someone just bought a used conversion off of eBay for 132.99. I had it on my watch list. They're really pricey! Though that seems to be the price they go for new...
rangerg
Post by rangerg »
Can't you just use standard Optima Mid gears and belt?
The response here on this Optima blogs talks about it:
https://www.blogger.com/comment.g?blogID=1702504335386067627&postID=7328820067000823771
You are leaving out the pulley.
Jay Dub
Post by Jay Dub »
Yeah, but if you intend to use the stock upper tray, belt guides, etc. the belt will rub excessively. Now if you were using a aftermarket chassis for saddle pack batteries and no guides or upper plate for example, then just a little trimming on the rear gearbox, and you are ready to go. -Jeff
Return to “Kyosho Forum”
