Salute project (was: Optima Belt drive conversion question)
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Post by EvolutionRevolution »
Does the belt drive conversion for the original Optima use the same diffs as the Optima Mid?
kaiser
Re: Optima Belt drive conversion question
Post by kaiser »
same belt, same diffs IIRC.
Yep, and same belt as the SWB Mid.
tamiyadan
Been thanked: 6 times
Post by tamiyadan »
EvolutionRevolution
Great. Looks like there is an Optima project in my future. :mrgreen:
notarex
Post by notarex »
There is an additional guide pulley and rear gearbox housing that was included in the conversion kit like the link spells out. They are a bit tougher to source.
tamiyadan
Post by tamiyadan »
Been thanked: 3917 times
I have said gearbox and pulley, they look pretty easy to make from stock gearbox and a couple small bearings. I know some have said they aren't needed..... But kyosho went to extra lengths to do it.. So I believe it couldn't hurt
I used an original belt conversion kit for CYANide, and made my own for Barney. If you make your own, one thing that's a bit of work in itself is a Lexan cover to seal in the guide pulley. Without it, the gearbox will be open to dirt & the elements.
Original:
Fabricated version that I made it from 3 pieces of spare Lexan and Weld-On acrylic cement, which I sealed on after gearbox installation with silicone:
http://www.rc10talk.com/viewtopic.php?f=30&t=21530&start=67
EvolutionRevolution
Re: Salute project (was: Optima Belt drive conversion questi
So after a bit of thinking, and because I want to make this a little bit different, I think I'm going to build myself a Salute.
What I have:
- Optima rear gear box
- Optima motor plate
- Mid diffs - will need to check whether I have both front and rear diff though
- Optima limited slip layshaft
- Optima hard counter gear
- Various misc. suspension bits
- Gold celebration nerf bars (NIP)
- Cross gold alloy c-hubs and front and rear uprights
- front shock tower
- bumper (cut-down)
What I need to check:
- Whether some of the unidentified aftermarket hop-ups I have are for the Optima
- Whether I have other Optima parts I don't know about yet
What I will need to get:
- Salute body + wing (TBG)
- Belt
- Front gear box
- All other alloy parts - thinking of getting a Pargu alloy parts set + the bumper brace
- Fibre-Lyte CF shock towers + chassis braces (maybe...)
Return to “Kyosho Forum”
