Slipper part #'s for original JRX2 car
obsidian
Post by obsidian »
Hey all,
I've started working on my original JRX2 today. I'm Keeping it an all stock 5 link except I'm going to put on my slipper and hydra-drive unit...I'm not quite sure, I might be missing more parts that I don't know about. I think I have most of the parts butI know I'm missing the slipper shaft and primary gear. If my memory serves me from the ancient past, I remember the primary gear using a pin and e-clip to be attached to the slipper shaft as apposed to the stock brass primary gear being pressed on to a splined stock shaft. Please correct me if I'm wrong.
What I'm looking for is a list of part #'s for the slipper assembly and hydra-drive assembly. Any help, as always, is appreciated.
much thanks.
cheers.
a01butal
Has thanked: 34 times
Been thanked: 40 times
Re: Slipper part #'s for original JRX2 car
Post by a01butal »
Here's a link for the friction slipper instruction which has part #'s http://vintagelosi.com/Manuals_files/Friction_Slipper_A3110.pdf
then here's the instructions for the Hydra-drive http://vintagelosi.com/Manuals_files/HydraDrive_A3100.pdf
Hope this helps.
This is all very interesting!
BloodClod
Been thanked: 10 times
Post by BloodClod »
I'm looking at the instructions posted and I'm wondering if it's possible to just use the slipper shaft and gear and then for the rest of the slipper parts fit a double slipper from a modern XXX?
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
I have done that!
RCveteran
Has thanked: 26 times
Been thanked: 200 times
Post by RCveteran »
Details on the new XXX slipper on the old losi slipper/hydra shaft please. Was it a direct fit?
shirochanwrx
Post by shirochanwrx »
I'm guessing that this was not an easy mod. I've searched but not seen a certain answer ... which transmission did you use, a retrofit or an LRM? Which topshaft?
I have a bunch of hydradrive, LRM, and retrofit parts, and I *believe you* when you say that the double slipper from the XXX can be used, but I'm not going to go and buy a bunch of XXX parts just to experiment ... I end up with too many bits hanging around that way!
Return to “Losi Forum”
Users browsing this forum: No User AvatarGoogle [Bot], User avatarZED32 and 6 guests
