I am building a New parts Losi JRX2 , it's very near complete, but after reading through much of this section I am in two minds regarding the trans choice.
Currently it has a new built LRM slipper with a A-3020 bearing diff, what trans would be the most desirable ?
I can purchase the Lethal Weapon slipper with the belt drive but I would have to re drill my chassis, I cannot find any info regarding the MIP trans, I am guessing it is a 3 gear with ball diff, I have also never come across the MIP trans for sale, but I am also in Australia so that may limit options, and I also have a complete running XX retrofit with bones....
What is everyones opinion on trans ?
Vintage trans, LRM Slipper vs Lethal Weapon Slipper vs MIP Slipper vs XX retrofit slipper
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: Vintage tans, LRM Slipper vs Lethal Weapon Slipper vs MIP Slipper vs XX retrofit slipper
If you decide to go the way of the Lethal Weapon, let me know. We can save you some dough over ordering off ebay.
It requires more than just a couple holes too. It requires modifying the rear bulkhead and arm mount a bit, and leaves you without a motor guard. It is however the only aftermarket trans kits that is still sold today. Just food for thought.
- Regular Member
- Has thanked: 3 times
Re: Vintage trans, LRM Slipper vs Lethal Weapon Slipper vs MIP Slipper vs XX retrofit slipper
Thanks GoMachV, I'll keep that in mind, I have been eying off several A & L parts,
Are the spur gears for the lethal weapon easily available ?
- Lonestar
- Has thanked: 623 times
- Been thanked: 171 times
I don't know the Lethal Weapon enough, but it could be pretty cool and you have Jeff @GoMachV here so that's a sure plusSnappy1 wrote: ↑Sun Jul 08, 2018 9:21 pm I am building a New parts Losi JRX2 , it's very near complete, but after reading through much of this section I am in two minds regarding the trans choice.
the LRM with A-3020 is ok when built right, and is original to the car. The retrofit came on the Pro-SE and LXT, which are two generations "younger" than your JRX-2, so, yes, it should fit but it is somewhat anachronistic.
The MIP is very rarely available for sale... if you set this yourself as a target, it's a pretty demanding one, but hey, if you come across one, more power to you (and money off you) if you can land it
Are you building a JRX2 as a runner or a shelfer?
Yes, they use standard old school pan car style gears like Kimbrough.
- 566 Views
Last post by adam lancia
- 3221 Views
Last post by CBR240
- 1669 Views
Last post by mdutcher
- 1132 Views
Last post by AllenB.5979
- 589 Views
Last post by JRxJoe
- 4627 Views
Last post by Dirtcar75
- 2529 Views
Last post by jamin
- 1030 Views
Last post by sschering
