Should i put a bearing in that gap that we see on the shaft? The box looks like it got chewed up a little from the slipper plate...
This is how the slipper is set up in that order
I am so close ...this is killing me.....any help would be great!!
There actually isn't supposed to be a spacer..alien3t wrote:should there be a washer or spacer on the top shaft. the push it out towards the motor plate so the packing plate doest go as far in?
didnt know if the long or short.
You need to use the spacer if you are using two short boss slipper plates, but since zuki250 is using the longer boss item on the gearbox side no spacer is required. Basically it appears that the hole in the gearbox casing needs to be opened up (using reamer, drill or file) enough to allow the 'boss' part to pass into the hole & sit 'home' on the end of the flat on the layshaft.... but not too large or the bearing won't be held captive by the case moulding.hondaman wrote:There actually isn't supposed to be a spacer..alien3t wrote:should there be a washer or spacer on the top shaft. the push it out towards the motor plate so the packing plate doest go as far in?
here is losixxkid's thread.. this page is regarding the slipper back plate: losixxkid build
Shawn
Thanks Dan for clearing it up.. I got fixated on the long boss plate and forgot there was a spacer on the short one..DerbyDan wrote:You need to use the spacer if you are using two short boss slipper plates, but since zuki250 is using the longer boss item on the gearbox side no spacer is required. Basically it appears that the hole in the gearbox casing needs to be opened up (using reamer, drill or file) enough to allow the 'boss' part to pass into the hole & sit 'home' on the end of the flat on the layshaft.... but not too large or the bearing won't be held captive by the case moulding.hondaman wrote:There actually isn't supposed to be a spacer..alien3t wrote:should there be a washer or spacer on the top shaft. the push it out towards the motor plate so the packing plate doest go as far in?
Shawn
Haha no probshondaman wrote:
Thanks Dan for clearing it up.. I got fixated on the long boss plate and forgot there was a spacer on the short one..![]()
Shawn
Users browsing this forum: Frankentruck and 6 guests
