RPM 2.65 compared to stealth
- LowClassCC
- Has thanked: 108 times
- Been thanked: 171 times
Re: RPM 2.65 compared to stealth
seeing the rpm 2.65trans is over 80% stealth what is there to compare? i weighed both and think the rpm was around 3 grams heaver due to the extra case material. the only other real difference is the gear ratio. 2.25 compared to 2.65. the modern rc10b4 has a 2.60 trans. thus for gearing with modern motors you can use the same gearing as they are using as a starting point and pretty much be dead on.
Hello,
is speaking of the RPM 2.65 Tranny case and top shaft, Can I mount a B4/T4 slipper on it? If not why?
Thank you
Thank you
- Lowgear
- Has thanked: 121 times
- Been thanked: 795 times
This will answer your question: http://www.rc10talk.com/viewtopic.php?f=38&t=14854&start=0
- 1287 Views
Last post by RC10th
- 1390 Views
- 2516 Views
Last post by Whiskers
- 971 Views
Last post by RC Chick
- 530 Views
Last post by SteveK
- 1500 Views
Last post by burnsmonkey
- 873 Views
Last post by aip47-2008
- 1069 Views
