B4 stealth transmission in a gold tub??
General info, Q&A.
djthomp
Post by djthomp »
Can you put a B4 stealth transmission in a gold tub 10? If so, what else do you need to do to make it functionable?
Thanks
rctenracer
Been thanked: 81 times
Re: B4 stealth transmission in a gold tub??
Post by rctenracer »
why the B4 trans? I would look for a steath for the gold tub.
MOmo
Post by MOmo »
djthomp wrote:Can you put a B4 stealth transmission in a gold tub 10? If so, what else do you need to do to make it functionable?
Thanks
Are you wanting the complete trans including case or just the guts? I suppose "anything" is possible if you drill etc. Trouble is, getting the holes for a newer B4 stealth just so w/o a template is tough. When the Stealth was first offered as an upgrade, it included a rather stout template for precise drilling (not that it didn't stop people from messing up the holes).
Agree with trying to find an RC10 w/ a stealth. I seem to recall trying this w/ my spare B4 and the inner guts are smaller IIRC.
MOmo
LowClassCC
Has thanked: 108 times
Been thanked: 171 times
Post by LowClassCC »
all original stealth parts can still be bought new except for the case and thrust bearing for the slipper. but those wouldn't be too hard to come by if you look or ask around for them.
keep your eyes open on ebay and 'im sure you can find one that's complete. other bolt in tranny options include; original 6 gear trans, mip trans, a&l belt trans, rpm stealth 2.65 conversion trans.
the rpm stealth conversion comes with new case and top shaft. you use the idle gear and diff along with the slipper out of the normal stealth. get the parts you can buy new for the stealth trans and the rpm conversion and all you are left needing is the thrust bearing for the slipper. i'm sure someone here knows where we may be able to find one that will work in place of an original one.
djthomp
Post by djthomp »
Thanks. I will either try to find a stealth tranny for the gold tub or try to get my 6 gear to run smoother.
aeiou
Post by aeiou »
The 6594 thrust bearing/washer kit is still available and can be used in place of the original 6586 thrust bearing & washers.
You can still buy all the parts needed to build a stealth transmission using the RPM 2.65 conversion case and the parts for a T3 slipper.
soniccj5
Post by soniccj5 »
I was able to stuff a B3 stealth in my gold tub.
You will need a dremel tool, file and a couple hours.
http://www.rc10talk.com/viewtopic.php?f=35&t=11310
I was tired of loosing bids on the gold tub stealth transmissions :D
ED
soniccj5
Post by soniccj5 »
Figured I would go on the bay to see if there were any gold pan stealths available. I found one complete with a buy it now price of 35$ US.
ED
rc10johnny
Post by rc10johnny »
[quote="djthomp"]Can you put a B4 stealth transmission in a gold tub 10? If so, what else do you need to do to make it functionable?
EDITED
rc10johnny, please refrain from offering things up for sale in the forums. we have a b/s/t for that. eventually, you can get access to it.
http://www.rc10talk.com/viewtopic.php?f=52&t=909
rc10johnny
scr8p wrote:rc10johnny, please refrain from offering things up for sale in the forums. we have a b/s/t for that. eventually, you can get access to it.
OOOOPPPPPPSSSSS bad habbit from other sites. will not happen again tryin to help when I can JohnnySr.
Motor'n
Post by Motor'n »
Did anyone ever get the B4 trans to fit? It has a few benefits over the original stealh for the newer brushless/ lipo power.
Racin since 1987
Users browsing this forum: No User AvatarBing [Bot], User avatarcarloco8 and 1 guest
