Removing glued on tires
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
Re: Removing glued on tires
No!, the microwave does something different entirely! we used to put tires in the micro with a coating of WD, if they are rubber-they will expand X2, and that's about it
- Has thanked: 183 times
- Been thanked: 157 times
like a marshmallow does?Charlie don't surf wrote:No!, the microwave does something different entirely! we used to put tires in the micro with a coating of WD, if they are rubber-they will expand X2, and that's about it
- Lowgear
- Has thanked: 121 times
- Been thanked: 796 times
Boiling is the only method I've ever tried. I've also only tried it on monster truck tires without foams. I wore rubber gloves as not to burn myself. Its worked about half the time for me.badhoopty wrote: i've never had any luck with boiling the couple times i tried it, and if you try it be VERY VERY careful when you remove the tires and try to peel them off the wheels. i burned the hell out my hands once when the outside felt cool but the inside foam was still very hot. one squish of the tire and i boiled a couple layers of skin off.
Doesn't boiling plastic make it stronger as well? The downside is making the plastic stronger means its more prone to breakage as its less flexible.
- Brandon G
My acetone "sealed tub" consists of an empty 1 gallon paint jug (can be purchased at any hardware store for a coupla bucks.) No problems with loss from evap dut to the good sealing of the lid.
I've found that Schumacher tires don't like acetone too well. It will melt the super glue ok, but be very careful when removing the tires from the wheels. If there are any nicks in the rubber, it will tear VERY easily. It also makes the tires expand a bit, but if allowed to dry out for a few days, they go back to normal.
I've had a pair of Panther tires shrink down to an unusable size after acetone, but those are the only one's that I had issues with besides the Schumachers.
Foams can be reused too if they are in good shape to begin with. They will be swelled and easy to tear after the bath, but if you be careful while removing and let them dry out completely they go back to their original shape.
the boiling thing worked for me on my rims it does soak the foams though just boilded the water and fliped ever few min and gently pulled the tire away wearing chemical cloves
some of my cars rc10 rc10t RC10T2 rc10t3 rc10gt sc10 4X4 losi xx4 tlr 22, duratrax exb, rs4 super rc10 worlds trf801x and trf801xt td10
nitro rs4 rs4 ev0 mirage v spec venum creeper
desc410v2 pro sc18 rc18 team turingy go cart and sct slash 2wd
Brandon G wrote:My acetone "sealed tub" consists of an empty 1 gallon paint jug (can be purchased at any hardware store for a coupla bucks.) No problems with loss from evap dut to the good sealing of the lid.
I don't know much about Schumacher tires but I'd bet the Panther's were "c" compound. Those, Losi pink, Jconcepts gold, Proline R3 or Mc will all shrink if exposed to acetone, Most all the other compounds from those brands should be ok.
I've used the oven method on losi pink numerous times (I race a track that calls for pink slicks, the foams wear) with good success. After baking them off the tires need traction compound to be sticky again though so something does change after this.
We are all heading towards old age. Get there slower by bike.
- 27 Replies
- 4944 Views
Last post by LosiXXkid
- 2187 Views
Last post by RedScampi
- 2260 Views
Last post by JOESGARAGE
- 2835 Views
Last post by Winger
- 1086 Views
Last post by rc10johnny
- 613 Views
Last post by SoloGraphix
- 1441 Views
Last post by Bong024
- 1090 Views
Last post by R6cowboy
Users browsing this forum: morrisey0 and 6 guests
