Are brushed motor bearings press fit or glued?
azone
Has thanked: 135 times
Been thanked: 115 times
Post by azone »
I need a yokomo endbell for one of my old modified motors. They are plentiful but hard to find in good shape. It is easier and cheaper to find stock motors with yokomo endbells. I'm wondering if the bushing or bearing in these brushed motors are pressed in or if they are actually glued? If pressed I could knock out a bushing and replace with a bearing...
Been thanked: 3917 times
Re: Are brushed motor bearings press fit or glued?
They are press fit in the case and slip fit in the endbell. Yes, you can swap a bushing for bearing. If the shaft is messed up from a pinion screw eating into it you might have trouble getting the bearing past it, so you may end up filing the shaft slightly.
azone
Post by azone »
GoMachV wrote: Sat Oct 05, 2024 9:29 pm They are press fit in the case and slip fit in the endbell. Yes, you can swap a bushing for bearing. If the shaft is messed up from a pinion screw eating into it you might have trouble getting the bearing past it, so you may end up filing the shaft slightly.
Nice. thanks.
R6cowboy
Has thanked: 871 times
Been thanked: 903 times
Post by R6cowboy »
GoMachV wrote: Sat Oct 05, 2024 9:29 pm If the shaft is messed up from a pinion screw eating into it you might have trouble getting the bearing past it, so you may end up filing the shaft slightly.
Just to add a little to this... I've spun the armature while holding the end of the shaft with very fine sand paper (very little at a time) to smooth out a slight rough spot from a pinion screw. Just enough so it's not difficult for a bearing to slide on and off.
-Jerry-
Users browsing this forum: No User AvatarTbot [Bot] and 2 guests
