Remove glued servo from predator lynx
I just picked up a composite craft predator lynx in good shape. In cleaning it up my only real concern is that the servo which is frozen up( it's been sitting a long time) is glued to the chassis. Is there a known trick to remove this servo. Be it chemical, heat, etc. I have never dealt with a graphite chassis before so your input it greatly appreciated. I'll post pics of the car when I get home tonight.
I'm not like them, but I can pretend...
Re: Remove glued servo from predator lynx
depends on the glue, but the graphite should be pretty tough. if it's crazy glue,(CA) then a soak in acetone should do the trick without damage to the graphite.
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Acetone desolves most glue types - and some types of paint and clear coat for that matter.
Test it where the bulkheads etc. mounts.
The clever guys doesn´t dip the entire thing - they put elevated in a container with acetone so it´s just the fumes doing the trick. I´m still looking forward to reach that level of smartness.
If You don´t need the servo, I´d try boiling the chassis as the first thing.
The freezer is supposed to manipulate the glue aswell.
Gone fishing
maybe you'll be lucky and find out it's only shoe goo. try hitting it with a heat gun to see if it becomes pliable.
That's the problem, it was done so cleanly that I can't see what was used. I was mainly worried about acetone damaging the chassis. Also didn't want to do a snatch and twist. I'll have to get a better look at it tonight. Thanks for the tip.
- 1241 Views
Last post by Frankentruck
- 4769 Views
Last post by TravelinTravis
- 65 Replies
- 10532 Views
- 2712 Views
Last post by xanadu
- 3252 Views
- 422 Views
- 20 Replies
- 2239 Views
Last post by davidka
- 27 Replies
- 4910 Views
Last post by LosiXXkid
