Removing foam tires?
Best way to remove foam tires from rims? Working on RC12L and putting rubber tires on, thanks.
OLD SCHOOL!
- RC10resto
- Has thanked: 1487 times
- Been thanked: 550 times
- RABIDFOX50
- Has thanked: 10 times
- Been thanked: 5 times
- RC10resto
Re: Removing foam tires?
It's possible, but I guess I assumed he was removing dried out or worn out Foams.
I have seen Acetone give life to tires (sometimes).
- Been thanked: 325 times
I've read from other members' experiences on here that acetone, even just the fumes, CAN ruin old foam tires. It won't affect nylon or rubber, though.
I’m going to put on rubber on tires, foam tires are dry and cracked.
OLD SCHOOL!
- KidAgain
- Business Member
- Has thanked: 513 times
- Been thanked: 431 times
takes a couple of days
- RC10resto
It all depends.
I have had some loosen up in 30 minutes, full soak method not vapor.
Your results will vary
I've done it a few times to remove CA glue and stubborn servo tape adhesive remnants from chassis plates, leaving it in the bag for 24 hours. That worked for me both times.
Ok, so best glue to use for old school duratrax rubber tires to rims?
OLD SCHOOL!
- 1824 Views
Last post by Russ Winn
- 2604 Views
Last post by corman007
- 1369 Views
Last post by terry.sc
- 1228 Views
- 788 Views
Last post by templeofspeed
- 1030 Views
Last post by Heffay
- 666 Views
Last post by TycoTamiya4eva
- 1959 Views
Last post by bully
