What CVDs would Fit on an RC10 Graphite with RC10T arms?????
- Has thanked: 19 times
- Been thanked: 29 times
Let's say hypothetically(spelling please) i was able to land an RC10 Graphite, and wanted to convert it into a Truck, what kind of CVDs can I use when I install rear RC10t arms??
Is it at all possible to do this conversion??
Has anyone on here done it??
THank you?? I guess??
Am I still asking questions??
Dough i am, aren't I?? oh geeshh.
- shodog
- Has thanked: 3 times
- Been thanked: 86 times
Re: What CVDs would Fit on an RC10 Graphite with RC10T arms?????
a set of RC10T CVD's should work. the rear chassis drillings on the RC10T is the same as the RC10 and it uses the same arm mounts. The chassis will be shorter so you might have a tough time making a body fit.
Oh brother, so the rc10 graphite has a shorter wheel base than the rc10t? so any suggestions as to what body might work??
I might just keep my eyes peeled on ebay, and try and get me an RC10T.
How's about a beetle bodied RC10 Graphite Truck, with RC10T blue RPM arms, blue tierods, RPM ball cups, Maybe use one of them Kamtec bodies , oh geez I'm getting ahead of myself.
That'll stick out in the Nationals 2wd truck class, won't it??
- Has thanked: 28 times
- Been thanked: 957 times
you'll also have to modify the front kickup on the graphite chassis to except the 10t front bulkhead.
- Has thanked: 15 times
- Been thanked: 35 times
or dare i say it... cut off the graphite kickup and use a truck nosepiece?...scr8p wrote:you'll also have to modify the front kickup on the graphite chassis to except the 10t front bulkhead.
yea for a queenbadhoopty wrote:or dare i say it... cut off the graphite kickup and use a truck nosepiece?...scr8p wrote:you'll also have to modify the front kickup on the graphite chassis to except the 10t front bulkhead.
Can't I just slap on som front RC10T arms on the Graphite Bulkhead??
you sure can. if you want your front track width an inch wider than the rear.tecnica2001 wrote:Can't I just slap on som front RC10T arms on the Graphite Bulkhead??
No no I mean, I would be using Rear RC10T arms as well, would it still be 1" wider in the front if I had rear Truck arms??
the buggy kickup is wider than the truck kickup.
Ok so I'm scrapping this Idea, cause there's no way I'm gonna cut off a graphite chassis, for one, and I'm not going to be running a retarted looking truck with way too wide front suspension
I guess is back to the drawing boards. If I do get the graphite, I'm restoring it and selling it
- 901 Views
- 595 Views
Last post by juicedcoupe
- 1313 Views
Last post by limestang
- 780 Views
Last post by Mtherr1988
- 96 Views
Last post by Bottom Feeder
- 21 Replies
- 2447 Views
Last post by RichieRich
- 32 Replies
- 6861 Views
- 1111 Views
Last post by justinspeed79
