Hi team,
I'm looking for a little help on this. I want to put some latest generation shocks on my RPM Worlds arms runner. It looks however, that most of the front shocks are going to be too short. The RPM kit (7077/7079) uses 1.02 shocks in the front and 1.32 bodies with 1.02 shafts in the rear. I'm hoping that I'm not the first person to go down this route, does anybody out there know what current gen shocks will line up in terms of length and stroke?
Thanks!
Dave
Best current generation shocks to fit RPM Worlds arms RC10
- Has thanked: 40 times
- Been thanked: 34 times
Re: Best current generation shocks to fit RPM Worlds arms RC10
Apparently I didn't use the search function properly as a couple posts on this came up after I hit go, but nothing definitive.
Does anyone out there know the actual secret recipe for this? Thanks!
- Has thanked: 10 times
- Been thanked: 447 times
The truck shocks are usually the right thing. 1.02 front and 1.32 rears.
Some of the newer shocks are shorter bodies in the rear (1.18). After that all the big bores went metric.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Short course or stadium truck shocks should be fine. As far as I know, most are approximately the same length as earlier truck shocks.
If there is a place of concern, it'd be the rear shocks. Some of the newer rear shocks are a little longer, which would slightly limit compression when used on a buggy.
If using AE shocks, this might help.
- 779 Views
Last post by RC104ever
- 703 Views
Last post by surgetek
- 559 Views
Last post by B4maz
- 1352 Views
Last post by Synergy
- 780 Views
Last post by delsami
- 859 Views
Last post by tecnica2001
- 1100 Views
Last post by shane
- 30 Replies
- 6827 Views
Last post by juicedcoupe
Users browsing this forum: Google Adsense [Bot] and 30 guests
