Converting to metric fasteners
- Has thanked: 22 times
- Been thanked: 21 times
So I ran into an RC Screwz kit for the B4.2 in metric sizes. I’m under the impression that the RC10B series didn’t make the switch to metric until the B5, and I vaguely remember using imperial drivers on my FT B4.2 (don’t remember for sure).
Dumb question but will the metric screws bolt right on?
- Has thanked: 1013 times
- Been thanked: 472 times
Re: Converting to metric fasteners
They will work, but they will make they widen the screw holes. So once you use them, you will be stuck there. If you have good plastics you may want to reconsider, however if the plastics are a bit worn out, metric hardware will help everything sit snug again.BeastyShout wrote: ↑Tue Apr 02, 2024 12:39 am So I ran into an RC Screwz kit for the B4.2 in metric sizes. I’m under the impression that the RC10B series didn’t make the switch to metric until the B5, and I vaguely remember using imperial drivers on my FT B4.2 (don’t remember for sure).
- gtv1
- Has thanked: 5 times
- Been thanked: 17 times
They are close, but not a direct replacement. If you are going to do it, best get a M3 Tap and tap the threads or if you have worn plastics you could helicoil them to a m3 thread.
- RC10th
- Has thanked: 40 times
- Been thanked: 1015 times
Metal parts like the motor plate won't thread unless you re-tapped them to 3mm. The upper shock mounts and steel balls in the shock ends won't fit 3mm unless you change them, and any through hole will be tight and need to be opened up.
What do they offer for the 5-40 threaded screws? 4mm?
Thanks. The plastics are fairly beat to crap, it looks like. My plan was to replace the fasteners and put one of those chassis protector stickers on.JosephS wrote: ↑Tue Apr 02, 2024 1:16 amThey will work, but they will make they widen the screw holes. So once you use them, you will be stuck there. If you have good plastics you may want to reconsider, however if the plastics are a bit worn out, metric hardware will help everything sit snug again.BeastyShout wrote: ↑Tue Apr 02, 2024 12:39 am So I ran into an RC Screwz kit for the B4.2 in metric sizes. I’m under the impression that the RC10B series didn’t make the switch to metric until the B5, and I vaguely remember using imperial drivers on my FT B4.2 (don’t remember for sure).
That sounds like a best case for metric fasteners. People have had good luck wet sanding plastic chassis into looking nice.BeastyShout wrote: ↑Tue Apr 02, 2024 6:02 amThanks. The plastics are fairly beat to crap, it looks like. My plan was to replace the fasteners and put one of those chassis protector stickers on.JosephS wrote: ↑Tue Apr 02, 2024 1:16 amThey will work, but they will make they widen the screw holes. So once you use them, you will be stuck there. If you have good plastics you may want to reconsider, however if the plastics are a bit worn out, metric hardware will help everything sit snug again.BeastyShout wrote: ↑Tue Apr 02, 2024 12:39 am So I ran into an RC Screwz kit for the B4.2 in metric sizes. I’m under the impression that the RC10B series didn’t make the switch to metric until the B5, and I vaguely remember using imperial drivers on my FT B4.2 (don’t remember for sure).
This is what the plastics look like.JosephS wrote: ↑Tue Apr 02, 2024 9:52 amThat sounds like a best case for metric fasteners. People have had good luck wet sanding plastic chassis into looking nice.BeastyShout wrote: ↑Tue Apr 02, 2024 6:02 amThanks. The plastics are fairly beat to crap, it looks like. My plan was to replace the fasteners and put one of those chassis protector stickers on.JosephS wrote: ↑Tue Apr 02, 2024 1:16 amThey will work, but they will make they widen the screw holes. So once you use them, you will be stuck there. If you have good plastics you may want to reconsider, however if the plastics are a bit worn out, metric hardware will help everything sit snug again.BeastyShout wrote: ↑Tue Apr 02, 2024 12:39 am So I ran into an RC Screwz kit for the B4.2 in metric sizes. I’m under the impression that the RC10B series didn’t make the switch to metric until the B5, and I vaguely remember using imperial drivers on my FT B4.2 (don’t remember for sure).
The undercarriage looks pretty scratched up. Got an RPM front bumper coming in.
- Frankentruck
- Has thanked: 1589 times
- Been thanked: 1770 times
Why does it need oversized fasteners?
- 445 Views
Last post by SteveK
- 1093 Views
Last post by KrAcOn
- 1021 Views
Last post by Mr. ED
- 430 Views
Last post by juicedcoupe
- 683 Views
Last post by JosephS
- 517 Views
Last post by GeekSpeed
- 619 Views
Last post by midse
- 23 Replies
- 2233 Views
Last post by m_vice
Users browsing this forum: Bing [Bot] and 8 guests
