Hi guys.
I am working on rebuilding a gold pan (Cadillac, I believe) to be a fun runner. I am going to keep the 6-gear and everything. I am looking at the old shocks and was wondering if there are modern equivalents that are the correct size. I know I have .56 front and 1.32 rear, but how do those lengths correspond to new aftermarket shocks? All of the new stuff is like 60mm, 80mm, etc. and I'm not sure what lengths to get. TIA!
Gold Pan Metric Shock Sizes
- Has thanked: 55 times
- Been thanked: 92 times
Re: Gold Pan Metric Shock Sizes
If you measure the eye-to-eye length of the shocks you have that should give you an idea. The length of the shock body will need to be short enough to avoid the shock bottoming out before the chassis.
Around 90mm for the rear and 65mm for the front.
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
I measured 64mm in the front and 87mm in the rear (with limiters), eye to eye. So, the above mentioned 65 and 90 should do.
Might need to slightly limit the rear.
- 1734 Views
Last post by juicedcoupe
- 409 Views
Last post by illshou
- 857 Views
- 303 Views
Last post by CustomCarbon
- 430 Views
- 820 Views
Last post by shane
- 982 Views
Last post by Dr XX
- 878 Views
Last post by dimebag d.
