metric rear rc10 hubs
- Has thanked: 1013 times
- Been thanked: 472 times
I happened into a set of bones and axles that look like they fit a 10t, same length as stock side by side, but the axles are metric. Are there any hubs that would be close enough to the same off set and height, but are metric? Something like ruster/slash hubs?
I had some B6 hubs but they are very wide compared to the original rc10 hubs.
I've not had awesome success enlarging bearing guides in stock associated nylon in the past. I may try it for this low class build, but I'd rather just buy a part that would work
- juicedcoupe
- Has thanked: 231 times
- Been thanked: 1747 times
Re: metric rear rc10 hubs
This is a Traxxas carrier beside one from a 10T. They are the common 2WD version from the Stampede, Rustler, Slash, and others.
It isn't perfect but could probably be made to work.
You can also mix and match 3 and 4mm thick bearings to shift the axles one way or the other (this is an older 8mm bearing version but the newer ones use 11mm bearings).
Awesome. Thank you once again. You should be running a hobby shop.juicedcoupe wrote: ↑Fri Jul 22, 2022 4:04 pm This is a Traxxas carrier beside one from a 10T. They are the common 2WD version from the Stampede, Rustler, Slash, and others.
it looks like the Losi sct 22.0 hubs work as well.JosephS wrote: ↑Fri Jul 22, 2022 10:24 pmAwesome. Thank you once again. You should be running a hobby shop.juicedcoupe wrote: ↑Fri Jul 22, 2022 4:04 pm This is a Traxxas carrier beside one from a 10T. They are the common 2WD version from the Stampede, Rustler, Slash, and others.
- 3314 Views
- 1887 Views
Last post by littleVETTE
- 1081 Views
Last post by chophead69
- 630 Views
Last post by juicedcoupe
- 868 Views
- 924 Views
- 1202 Views
Last post by JK Racing
- 1219 Views
Last post by sbcnyc
