RC10 buggy with long RPM arms
- Niki
- Has thanked: 3 times
- Been thanked: 36 times
NIXconcepts -Shapeways Shop- -I.materialise Shop-
--- Quadra-symmetric RC10 --- RC10 '91 Worlds Conversion --- Start of NIX91 story...
- Niki
Re: RC10 buggy with long RPM arms
PARTS:
Front end:
-10T kickup ASC7305 and bulkhead ASC7207
-Inner hinge pin ASC7209
-Front arm RPM80492
-Outer hinge pin ASC8423 or ASC7357
-Caster and steering block ASC6210 + ASC6225
-T3/B3 front axle ASC7221
-B4 Front wheel ASC9588 or ASC9688
Rear end:
-Inner arm mount "RPM73282 Arm Mounts 0-1" or "RPM73282 Arm Mounts 0-2" by NIXconcepts
-Inner hinge pin ASC6380
-Rear arm RPM73282 (inbuilt 3deg toe-in)
-Outer hinge pin ASC6381
-Rear hub ASC7364 for 3deg/side toe-in
-Rear hub ASC7367 for 1.5deg/side toe-in
-B4 CVA/CVD bone ASC9672/ASC9597
-B4 pin or hex wheel
Front end:
-Front arm RPM80492
Rear end:
- yellowdatsun
RC10T? If so, get a taller front shock tower, and longer front shocks.
You can see he already has the RC10T front end.
- Niki
1st and 2nd post updated...
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
Looks good. Nice repurposing of RPM stuff
- Has thanked: 14 times
- Been thanked: 57 times
The car looks great! The front shock tower I'm using would be perfect for your car.
This may be a dumb question but what is different about the inner arm mounts that you made VS. the stock Associated parts?
Could you post a pic of the bottom of the car, a pic with the body off, and also perhaps a pic with the wheels off?
- Niki
Biggest difference in arm mount is zero degree toe-in. Arm itself has 3 deg.
Arm mount location is also fine-tuned for B4 bone lenght. As you can see from the picture (with stock inner hinge pins) RPM arm should use shorter pins. This also affects arm mount design.
-N-
-N-
- JK Racing
Niki, looks great....I may need to attempt to make one.
- Regular Member
DO you have to use Associated part # 7305 nose plate
for the long arms up front.. Or can you use the stock worlds front end
- Niki
10T nose is needed.
- Regular Member
With the long arms is it legal for racing what else is needed to put them on the worlds buggy
- Niki
At least wheel nuts are outside 250mm. When I measured it with B4 front rims alone it was 250mm sharp on ground level. With wide tyres it's outside 250 for sure but maybe with ribs it's ok.
- BohemianBabyDev
- Regular Member
- Has thanked: 28 times
This has been extremely helpful as I have been digging and digging for an RPM front arm replacement for my RC10GT project.
Considering the front end of this is nearly entirely RC10T / GT
I should be able to just throw the RPM Nitro Rustler arms on my GTE Basher build with relative ease correct?
- 949 Views
- 32 Replies
- 6859 Views
- 758 Views
- 1100 Views
Last post by shane
- 732 Views
Last post by mikea96
- 1279 Views
- 595 Views
Last post by juicedcoupe
- 694 Views
Last post by cautrell05
Users browsing this forum: No registered users and 29 guests
