This Raco Roadrunner has been sitting in a shed for a good 20 years. It's previous owner obviously didnt have safe storage in mind. It came with almost nearly enough spare parts to build a 2nd Roadrunner ( with the exception of a frame , fuel tank, front shock towers, wheels & tires) .
My plan is to get this one running and driving without doing a complete teardown. ( I am famous for tearing stuff apart , losing motivation and not finishing projects) I would like to possibly find the missing parts I need and build a 2nd Roadrunner out of the spare parts, but that will be a project for later on.
Raco Roadrunner project
- Has thanked: 11 times
- Been thanked: 6 times
Re: Raco Roadrunner project
It has a decent layer of grime, spider webs and leaves. The steering servo is seized. Lots of rusty hardware. I had the idea of soaking the rusty hardware in apple cider vinegar to remove the rust. I'd rather not use the new in packs hardware yet.
I removed the steering servo , receiver and battery pack. Sprayed some simple green on the buggy and took it to a car was for a quick power wash. Yes , i plugged the exhaust and wrapped the carburetor to keep water from getting inside.
Here is the battery pack I need to find a replacement for. I also removed the carburetor. I am still trying to find a carburetor rebuild kit for it. I believe it will need more than just a cleaning and primer bulb. I bet the diaphragm is hard and crusty. I have had no luck on finding a direct replacement. Everything I have found so far will need to be modified.
I was happy to find that the engine does have spark.Shortly after I found one front shock tower has a hairline crack in it. Sadly, I do not have spares.
So that's my Roadrunner project. It will be a slow project that I will work on piece by piece . I refuse to do a complete teardown because I know I will eventually lose motivation and leave it in a pile of parts for months on end.
- coxbros1
- Has thanked: 1975 times
- Been thanked: 1756 times
with a little research u should be able to score a similar new carb on ebay for $15 or so....cool car btw!
- 1214 Views
Last post by mrlexan
- 1089 Views
Last post by duckhead
- 1558 Views
Last post by greene-r74
- 1150 Views
Last post by InetRC
- 1173 Views
Last post by Mr. ED
- 1252 Views
Last post by Jeff8877
- 197 Views
Last post by TycoTamiya4eva
- 1533 Views
Last post by Truckguy
