Some of the older Delta Super J cars are using white wheels. I think with the CK790 the red wheels were introduced.
The front wheels should be same dimensions maybe but is it possible using the red rear wheels on older Super J as well or are hubs or mounting something different?
Regarding rubber, is it possible using current 1/8 rubber on old Delta wheels or is the diameter different?
For the front wheels, someone knows the dimensions of the bearings?
Delta 1/8 wheels
Re: Delta 1/8 wheels
For the Delta Super Eagle frontwheels/axles, each wheel has TWO different sized bearings. Inner 1/4" x 1/2" and outer bearing 3/16" x 1/2".
- a01butal
- Has thanked: 33 times
- Been thanked: 39 times
Super J wheels that I have use 3/16" by 1/2" only.
This is all very interesting!
- 44 Replies
- 10130 Views
Last post by aip47-2008
- 19 Replies
- 1566 Views
Last post by clinehobbies
- 19 Replies
- 2120 Views
Last post by shirochanwrx
- 1985 Views
Last post by Eau Rouge
- 1825 Views
Last post by oca1
- 1660 Views
Last post by Bimdapogs
- 1195 Views
Last post by mk4
- 1293 Views
Last post by mk4
