DELTA Ck790E
- Banned Member
Re: DELTA Ck790E
is there any info on this? like a story , how you obtained it, pics of the parts???
- mrlexan
- Been thanked: 10 times
Re: DELTA Ck790E
Was that the NIB kit I saw recently on ebay from like Spain or some similar country?
www.gojammedia.com
www.gojammedia.com
- camlchris
- Been thanked: 4 times
Re: DELTA Ck790E
yes Spainmrlexan wrote:Was that the NIB kit I saw recently on ebay from like Spain or some similar country?
Re: DELTA Ck790E
Is the motor mounting adjustable or fixed just like the gas version? In the gas version, the engine mount cannot be shifted. Gear ratio is adjusted by changing the spur and pinion in pair (or something similar to pitch changes in the pinion).
- tamiya
- Been thanked: 7 times
Re: DELTA Ck790E
yeah we raced Delta Super-Js and the pinion goes thru bearing in the side plate - well supported
and the clutchbell was totally free-floating off the flywheel/clutch, nothing interconnecting
made engine swaps very fast... like under 2mins once i think?!
Ran Piccos & OPSes back then, with the Delta slide carb & flattop heatsink. Mainly broke conrods.
however when trying to gear lower... the spur becomes so big it runs very close to chassis plate;
the FRP juts out over the edge of the side plate and always clogged up with pebbles = chewed spur.
We'd just gring off like 5mm off the FRP edge to reduced spur damage.
Re: DELTA Ck790E
here are specific spare parts of the CK790E kit
12 cell unit
and a 6volt Astro flight inc : ASTRO 15 engine
12 cell unit
- 44 Replies
- 10130 Views
Last post by aip47-2008
- 19 Replies
- 1566 Views
Last post by clinehobbies
- 1474 Views
Last post by Woobie
- 344 Views
Last post by Phin
- 912 Views
Last post by V12
- 913 Views
Last post by romulus22
- 1269 Views
Last post by V12
- 1929 Views
Last post by juicedcoupe
