Delta stuff
Delta stuff
Hello
I´ve got some Delta spareparts that needs to be id:d
some screws that have an unusual head needs a flat screwdriver with a rounded tip ?
Anybody know to which model they belong.
Sorry about the small picture.
And my Delta 760 ??
And my Delta 760 ??
- Has thanked: 13 times
- Been thanked: 78 times
Re: Delta stuff
Those screws were called High Torque screws. I think these were used at several Delta cars but were much more expensive then usual screws. My Delta Super Phaser 1/12th also is using some of them but I think they were available as 8-32" only. Maybe they were aircraft grade screws.
- a01butal
- Has thanked: 33 times
- Been thanked: 39 times
Re: Delta stuff
An example of the screws is in the bag in #1 photo and further down the photo's is the Hi-torque driver for the Hi-torque fasteners.
http://web.me.com/rc500/rc500.net/parts_delta.html
This is all very interesting!
Re: Delta stuff
Thanks for the info guys.
Impressive as always
I can understand how the screws would be stronger that way.
I have the wings they showed on the link to.
- a01butal
Re: Delta stuff
The red parts in package look to be the servo horns for the Futaba FP-S7 servo's. The package with the wires appears to be the wing mounts which my CK800SJ uses with the red wing you show in another picture. Nice early parts you've got there.
Re: Delta stuff
Nice Delta CK760. Part SW 1846 is the steering pushrod end that mounts on the servo horn.
This is my CK750 SS showing the steering pushrod end:
Re: Delta stuff
Thanks for the info oca1 and a very fine car you have there.
Here´s a Delta front end added to a Carlsson Pro 80s rear.
Re: Delta stuff
Are those rod ends rare? I seem to have a couple packets of those, but with SG header cards..
- 44 Replies
- 10130 Views
Last post by aip47-2008
- 19 Replies
- 1566 Views
Last post by clinehobbies
- 747 Views
Last post by camlchris
- 1293 Views
Last post by mk4
- 1195 Views
Last post by mk4
- 576 Views
Last post by Dirtdiver
- 1985 Views
Last post by Eau Rouge
- 880 Views
Last post by GJW
