Project StealthMode...Minus The STEALTH
- LTO_Dave
- Has thanked: 46 times
- Been thanked: 225 times
I've finally finished the project that started my AE obsession. And thanks to Mr. Lexan, I found the perfect wheels & foams to finish it off.
It's such a simple design, but it took me forever to get it perfect. Please let me know what you think.
List of parts I used:
- TrackMaster graphite chassis
- TrackMaster graphite X Caliber direct-drive tranny
- McAllister lowering kit
- McAllister rear oval body mount
- MIP 1/4" CVD's
- AE shorty front arms
- RPM rear arms
- RPM rod ends
- RPM spring cups
- RRP titanium ball studs
- Pure-Tech hinge pin snap rings
- AE .56 gold shocks & soft springs
- Avid wheel bearings
- Mini Tech mesh wheels & foams
- Protoform Vortex L.D. Oval Wedge body
Pics:
- MIP 1/4" CVD's
- RPM rear arms
- RPM rod ends
- RPM spring cups
Pics:
- PBR Allstar
Re: Project StealthMode...Minus The STEALTH
that thing looks really cool dave! do something about the caster though, it's killin' me
- Has thanked: 28 times
- Been thanked: 957 times
ya...PBR Allstar wrote:do something about the caster though, it's killin' me
when using a chassis with no kickup, you need to use the left castor block on the right, right on the left.
- rc10johnny
That is sooooo sweet of a ride. I cant believe my eyes I had a couple of the front shock struts and cut them up. what a dummy I am. I also have a couple composit rear wings cut to fit if ya want one. its called a Twinn-K airfoil. LMK Johnny
- LTO_Dave
scr8p wrote:when using a chassis with no kickup, you need to use the left castor block on the right, right on the left.
I know, silly.
But, you also have to dremel the carriers. I don't feel like cookin' up a pot of dye just for two little parts. Maybe someday...
I just need to find some Cheetah castor wedges and call it a day.
- PBR Allstar
I would start with 20* blocks flipped left to right, that will give you 5* of caster, depending on how much steering you want you might have to use a dremel on the caster block to clear the sterring knuckle at full lock.
or, you could just buy new black castor blocks. no dye needed, and no waiting god knows how long for cheetah castor wedges to come along.LTO_Dave wrote:scr8p wrote:when using a chassis with no kickup, you need to use the left castor block on the right, right on the left.
I know, silly.
- Has thanked: 7 times
- Been thanked: 41 times
- HotRodJosh
- Has thanked: 3 times
Damn......this car looks PISSED.
"I've got a fever, and the only prescription.....is more cowbell."
Pinstriping by Josh
Pinstriping by Josh
- LTO_Dave
I just got back from trying to reverse the castor blocks, but didn't have any luck.
Maybe it's a combination of the parts I'm using (short arms, inline spindles & possibly 30-degree blocks), but it's physically impossible to switch the blocks because the spindles hit the A-arms. Maybe a different degree block would solve the problem, but all mine are the same degree. I could possibly remove a portion of each arm, but I'll just annoy everyone with my wicked camber.
Customworks blocks can be reversed. That car should be called the Murder Wedge
Captain Castor, or Castor Canundrum, or El Castorbator... or
- THEYTOOKMYTHUMB
- Has thanked: 2122 times
- Been thanked: 1346 times
One word: Creamdream! An absolute creamdream! I threw in a few bonus words because that is one sweet rig!
- railey72
That thing looks mean.
You were the class bully weren't you.
- 795 Views
Last post by rctenracer
- 94 Replies
- 21966 Views
Last post by olfrjf
- 1846 Views
Last post by Mr Casual
- 577 Views
Last post by markt311
- 21 Replies
- 3634 Views
Last post by MeltingPlastic
- 74 Replies
- 9946 Views
Last post by minimini
- 35 Replies
- 3958 Views
Last post by Winger
- 19 Replies
- 4392 Views
Last post by mk-Zero
Users browsing this forum: GreenBar0n and 67 guests
