Project "RC10 Stealth-4" by mini (July 28th, 2015 updated)
- minimini
- Location: KWS@Hong Kong; 3.5 hours' trip to meet tiger1 and only 7,777 miles from Doug
- Been thanked: 9 times
There are different RC10 4WD conversions in the past.....but the prices are terribly high which I am not able to afford any one of them now......so I decided to build my own one instead......
Choosing the front gearbox is troublesome.......with the great help of Jeff (Gomachv) .....I finally decided to put a stealth gearbox in front ......keeping the gear ratios the same between the front & rear .......& no doubt that the drive-train is super smooth & reliable too ......
Jeff's build thread --> http://www.rc10talk.com/viewtopic.php?f=35&t=33503
Stay tuned
Stay tuned
- minimini
Re: Project RC10 Stealth 4 (June 6 updated)
Front gearbox:
To start with....I am using the rere stealth gearbox.....drill a hole on each side in the idler gear slot......make sure to align the two new bearing holes ....
- minimini
Replace the idler gear by a Robinson pinion......with appropriate shimming in between......
- minimini
Throw in all components into the gearbox.....silky smooth !!.......
- minimini
adding a pulley......I chose the Japanese brand "Square".........while the 3 Racing pulleys do the same thing.....
- Been thanked: 4 times
Re: Project "RC10 Stealth 4" (June 6th updated)
That's brilliant!
- minimini
Re: Project "RC10 Stealth 4" (June 6th, 2014 updated)
nose plate cut narrow ..... with new set of holes drilled.......
- soniccj5
Looks like this might have either dynotech or Jake arms in the front?
Looking forward to it.
- SMOKE-DOG
Wow. Love this type of creative RC building.
Will be following this one.
TC showroom: http://tamiyaclub.com/showroom.asp?id=18447
- minimini
The front end would be too wide if I use the truck nose plate plus buggy wide track arms......that's why the nose plate was cut even narrower than the truck one.......soniccj5 wrote:Looks like this might have either dynotech or Jake arms in the front?
Likely the front end would be using the buggy wide track arms or RPM Team car arms.....
- mk-Zero
- Business Member
- Has thanked: 4 times
- Been thanked: 19 times
- Bottom Feeder
- Has thanked: 10 times
- Been thanked: 23 times
Why the longer cap screws and big washers when you could recess both the cap heads and smaller locknuts in the transmission case? It would look a lot cleaner and more streamlined. Just my opinion...
- minimini
those longer cap head screws & big washers are for test fit onlyBottom Feeder wrote:Why the longer cap screws and big washers when you could recess both the cap heads and smaller locknuts in the transmission case? It would look a lot cleaner and more streamlined. Just my opinion...
- Has thanked: 823 times
- Been thanked: 2419 times
How much rake are you going to try? I ended up around 10 degrees on mine, simply looking at what kyosho did with those same suspension components. MIP ran the stock kickup and then brought the caster back at the hub carrier on theirs. Can't wait to see this one come together!
Factory Works website
- minimini
cut out part of the front suspension mounts
anchore the front gear box & suspension mounts to the front tower.....which is the most important component in this project....
- 2230 Views
Last post by ace028
- 354 Views
Last post by dinglem
- 6358 Views
Last post by Vale
- 1737 Views
Last post by phoenix
- 20 Replies
- 2277 Views
Last post by shredderboy
- 1240 Views
Last post by murphy3428
- 22 Replies
- 2894 Views
Last post by wyldbill
- 37 Replies
- 4755 Views
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], juicedcoupe and 41 guests
