Tamiya Hex Questions for wheels
mikedealer
Post by mikedealer »
does anyone know what size hex these are?
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=390035285405
are the hexes the same size as the ultima/optima? or different?
civilguy
Has thanked: 5 times
Been thanked: 14 times
Re: Tamiya Hex Questions for wheels
Post by civilguy »
Those are 12mm hex.
You'll need to have a Kyosho person chime in on whether or not those buggies had 12mm or not.
Jeff
mikedealer
awesome yes, kyoshos are 12mm hex also, thank you!
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
Mike, these adapters will not fit on an ultima axle. They are for the frog axles which I think is 6 mm diameter. Beside that the threaded part of an ultima axle will be inside of the adapter leaving nothing to thread the nut on.
If you want wider axles and hexes you can use (kose?) tlt-1 option parts: as I did for my ghostrider project, or the TGX wide axles with about 10mm thick plastic hexes
mikedealer
actually, wanted these for a frog so i can use same rims/tires on my ultima lol
Mr. ED
Post by Mr. ED »
ah , right. Then those are exactly what you need, but much cheaper are the hpi truck wheel adapators. With a small modification, the adaptors for putting hpi wheels on a monsterbeetle will do the exact same as these tamiya parts.
Mr. ED
Post by Mr. ED »
mikedealer wrote:actually, wanted these for a frog so i can use same rims/tires on my ultima lol
What ere you going to use on the front of the frog? Can you put the steeringknuckles of the ultima rb5 on the frog monsterbeetle style?
(you could also try prying 8x5 bearings into asso front wheels I think)
Brandon G
Post by Brandon G »
I believe RCmushroom.com has the same part for less $.
Return to “Tamiya Forum”
