parts list to convert re-release Worlds car to B5(hex)wheels
Hey guys,
this might of been covered already, but I couldn't find it.
I have a Worlds re-release car all built and ready to race, but as my other racer is a B5M, I would love to share wheels and tires, if that's possible
is there a conversion parts list?
thanks
thanks
- Bottom Feeder
- Has thanked: 13 times
- Been thanked: 25 times
Re: parts list to convert re-release Worlds car to B5(hex)wh
This thread doesn't answer your question exactly but it will have lots of useful info. It's long but worth the read.
http://www.rc10talk.com/viewtopic.php?f=38&t=8848
The main problem you're going to run into isn't that the B5 wheels are hex drive, it's that the offsets are very different.
thanks for that.
I guess you are right, getting the correct width is the issue
Things like arms, turnbuckles, driveshafts, axles etc would need to be changed
might be more trouble than it's worth
But, I know it must be possible
- slotcarrod
- Been thanked: 45 times
Hey Stu, this Niki's mod for hex on the 91 car, It will work for any pan type RC10 as well.
http://www.rc10talk.com/viewtopic.php?p=428105#p428105
Rod Littau
thanks Rodslotcarrod wrote:Hey Stu, this Niki's mod for hex on the 91 car, It will work for any pan type RC10 as well.
I'm building up a couple of cars in the hopes we get to race some indoor off road
- Niki
- Has thanked: 3 times
Hi,
Other option is to use NIX63551 arms and B4 bones. This way you can use Worlds Car hubs and bearings from the kit.
In this mod suspension layout isn't "Worlds Car" anymore as outer hinge pin moves out.
http://www.rc10talk.com/viewtopic.php?f=35&t=37682&start=60#p429156
With hub NIX63652 Rod pointed out suspension layout stays original.
-Niki-
-Niki-
- 3582 Views
Last post by rctenracer
- 1479 Views
Last post by Lonestar
- 1069 Views
Last post by mk-Zero
- 2949 Views
Last post by tdub77
- 2289 Views
Last post by Superathlete
- 1120 Views
Last post by Phin
- 1555 Views
Last post by RC10th
- 23 Replies
- 3143 Views
Last post by NickTheGreek
