RC10T Hub Carrier 3/16 conversion!!!
tecnica2001
Has thanked: 19 times
Been thanked: 29 times
Post by tecnica2001 »
a01butal
Has thanked: 34 times
Been thanked: 40 times
Re: RC10T Hub Carrier 3/16 conversion!!!
Post by a01butal »
#7366 would be 0 degree and this one above 7367 is for 1 1/2 degree and both are for b2, t3, b3 at least that's what the catalog says.
This is all very interesting!
tecnica2001
So what would the correct one be??
I want to convert my 10t to 3/16 hubs, then install a posi lock quick change set up on it... :D
tecnica2001
Been thanked: 1319 times
the only thing you should have to change is the bearings. the hubs were the same whether you have 1/4 or 3/16 axles.
tecnica2001
Awesome,
Thanks for the info Scr8p :D
Now, onto my search for a quick change posi lock thingy.... 8)
tecnica2001
I'm running the Stock RC10T rear hub carriers and suspension mounts, I really don't care that much about the degrees, I just wanted to achieve the use of 3/16 bearings, so that I can install a quick change posi lock system on my 10T.
Has anyone attempted this?? quick change truck conversion on a 10T??
It shouldn't be that difficult to do, the quick change conversion is meant for the T4 and 10GT, so It should fit the 10T with no problems.... :D
markt311
Post by markt311 »
works great, you just don't get the 1/2" bearings the gt2 uses.
http://www.amainhobbies.com/product_info.php/products_id/9119
you need to have CVD's obviously
Mark
Group B
Post by Group B »
If cost is no object, I would recommend using the RPM big-bearing rear hub carriers, pick up some 1/2 x 3/16 x .195" bearings (just don't buy the hub carriers with the bearings - RPM uses thinner bearings with plastic spacers), and pick up the MIP 3/16" quick-change cvds.
Return to “RC10 Truck Forum”
