rear hub conversion
General info, Q&A.
BTracer
rear hub conversion
Post by BTracer »
I was wondering what the best way to convert to a hex style hub would be. I came up with this. It's a hub off of an HPI super nitro. The only thing is that you have to bore out the hinge pin hole to accept the associated hinge pins. It even takes the stock RC10 dogbone perfectly, though I used the HPI one in the pic. Please feel free to suggest any better ways to do this conversion.
Re: rear hub conversion
easiest way would be to get the hpi super star rear wheel adapter kit. it comes with the proper adapter to use on the rc10 1/4" axles.
BTracer
Post by BTracer »
That would be much easier. Thanks scr8p
i know JK Racing uses those adapters, along with i think ofna rims to use 2.2 tires. i think they're from a 12th scale truggy, or something like that.
maybe JK can confirm that. :wink:
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
Confirmed....
HPI adaptors and OFNA CRT .5 2.2 rear rims, makes the rear end the same width as todays cars (eyeball measureing against my RB5 this past racing weekend.)
Touring car wheels should work with no issues either. Check your backspacing and axle hole sizing though.
RC Chick
Post by RC Chick »
scr8p wrote:easiest way would be to get the hpi super star rear wheel adapter kit. it comes with the proper adapter to use on the rc10 1/4" axles.
And which wheels fit the RC10 using those adapters.
RC Chick wrote:And which wheels fit the RC10 using those adapters.
these are the one JK uses with the adapters.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXSEF3&P=SM
JK Racing
Post by JK Racing »
Here is what they look like installed with Panther Puma tires....
rc10DS fan
Post by rc10DS fan »
would this idea work on my ds??
JK Racing
Post by JK Racing »
standard rc10 axle and DS axles are the same, I would imagine, so in essence...yes, should work.
MONSTER
Post by MONSTER »
Maybe Ive oversimplified your situation in my mind, but Ive just drilled out the Holes in the Hexes for some Cars, when the Axle was too big for the Hex I had handy.
