RPM Rear Hub Carrier Set
General info, Q&A.
broodenburg
Has thanked: 35 times
Been thanked: 10 times
Post by broodenburg »
Hi,
I run a T3 and would like to use the RPM70172 RPM Rear Hub Carrier Set.
It doesn't fit however, my CVD seems to bee to "short". What am I doing wrong, wrong type of CVD (do I need the T4's CVD) or do I need other rear arms?
thanx!
Re: RPM Rear Hub Carrier Set
T3 uses a unique rear hub carrier, actually T3 and B3. So either use the factory ones, or find T3/B3 rpm rear carriers.
you may be able to use 70172 with T4 axles, but I don't have any to know for sure.
it appears 70272 might be what you need from rpm's website.
broodenburg
thanx, it looks like the RPM hubs won't work for me :(
I hope somebody knows for sure if it will work with T4 CVD's
on the other hand, I could be trying something stupid :?
