xxt cr rear arm length??
lowrydesign
Has thanked: 11 times
Been thanked: 22 times
Post by lowrydesign »
so i have a xxt cr from 97 and the original rear arms are shorter than a pair of graphite arms i picked up, now the drive bone is barely long enough even with the spacer moved to the inside..... did losi change something??
also i noticed that the lower shock mount changed.... see pics
help!!
bone length too short
new arm mount
old arm mount
bearrickster
Re: xxt cr rear arm length??
Post by bearrickster »
those dont look like the right arms? I am not for sure as my XXt in in route to NZ. to fasterlauder.
LOSI RULES!!
Bearrickster's Rides
lowrydesign
what are these for then?
what else do you suggest?
bearrickster
the ones with the bolt on shock mount is what I had on mine? not the moulded in ones you have pictured? may be XXXT they were longer
LOSI RULES!!
lowrydesign
strange they say xxt on them, i wonder what the gas truck used?
bearrickster
I dont know but it wouldnt be the first Losi part I have seen in the wrong package??? I bought a Jrxt front mount the header card said it was a set of tires??
LOSI RULES!!
toykilla
Post by toykilla »
I have NIP XXTCR and XXXTCR rear arms. They both have the same part number.
lowrydesign
are they graphite with removable shock mounts?
JK Racing
Has thanked: 139 times
Been thanked: 246 times
Post by JK Racing »
XXT non CR rear arms...not the same as XXT-CR arms.
lowrydesign
so non xxtcr arms are longer??
so on a xxt how does a longer arm get get used if the drive axles are the same? hub carriers????
bearrickster
Those are just the wrong arms the XXT arms have the bolt on shock mount. they are packaged wrong
LOSI RULES!!
lowrydesign
damm that sucks what should i do with them......
bearrickster
take them back were you got them??
LOSI RULES!!
y2kgtp
Post by y2kgtp »
bearrickster wrote:take them back were you got them??
If possible. 1 Staple holding a package together is prob easy to repackage. I'm sure someone on here has the right parts....
JK Racing
Post by JK Racing »
lowrydesign wrote:so non xxtcr arms are longer??
The change from the original to the CR version was the inner mounting point of the arm. On the original, the arm mounts were part of the T-plate, like the current Duratrax set up. The CR version has a pivot support mounted onto the plate, making the hinge points a tad wider, thus shorter arms.
Return to “Losi Forum”
Users browsing this forum: No User AvatarAmazon [Bot] and 4 guests
