MIP Shock Shafts
General info, Q&A.
bscotti
MIP Shock Shafts
Post by bscotti »
Do MIP shocks shafts for Losi shocks "work" with Associated shocks? I don't know if the shaft diameters and piston attachment methods are the same.
Also, did MIP make suspension hinge pins back in the day?
Classics rule, moderns drool
Re: MIP Shock Shafts
as long as they're for the associated shocks, they'll work the same as the stock shafts do (piston, e-clips).
bscotti
Post by bscotti »
I guess I better stop hitting the nog so hard ... Meant to ask if Losi shafts work with AE shocks ... edited the orig post.
aconsola
Post by aconsola »
The main difference between the losi and AE shafts is the thread size. The AE shafts taper down to a 4-40 thread, while the losi are larger, 5-40 I think.
The lengths are slightly different between the 2 which is not so much of an issue as you can simply use internal/external limiters if they are too long.
On the few that I sampled just now, the piston fitting space was the same between both stock ae and losi.
Group B
Post by Group B »
I'm not sure if you're interested or not, but MIP titanium nitride coated shock shafts and the blue siliicone o-ring seals are still available for the associated trucks and buggies. I recently got a set of the shafts for my 10T on ebay.
Worse comes to worse. I guess you could just drill out the bottom shaft fitting a bit prior to threading them to accept the larger shafts.
brian, which associated ones do you need?
bscotti
Post by bscotti »
the ones to go with my Andy's build ... 0.71 and 1.32?
