traxxas trx1 shock shafts
ive bent my traxxas trx1 shock shafts so does anyone know of alternatives ?
Re: traxxas trx1 shock shafts
you should be able to use pretty much any 1/8" shock shaft, as long as it's close to the right length. Maybe associated 1.02" shafts would fit well or losi .9" shock shafts? little tricky on the threaded end though, the traxxas ones are 3mm thread, associated is 4-40 and losi is 5-40.
stock ones available here(hard chrome):
http://buy.traxxas.com/product_info.php?products_id=4399
they are the 'long' shafts and should be easily available since they are still in production.
Traxxas still uses the same shafts on their shocks. 1664 is the standard chrome shafts or you can go with 1664T, which are the ti-coated hardened shafts. Same shafts that are used on the big bores and ultra shocks that come standard on the Rustler/Bandit/Stampede/Slash/Slash 4x4 etc.
Ok thanks for the help and have got 1664t
Now what is the stronger shaft for 2764?
Designer of the Lazer ZX / ZXR Tub Chassis (now available again from Fibre-Lyte)
Sponser links below
http://www.fibre-lyte.co.uk/
http://www.kamtec.co.uk/
Sponser links below
I don't know of a 2764 Traxxas part number.
What shock are you looking for upgraded shafts for?
Closest thing I see is #2664, which is a long big bore shock body. If that's what you meant, the same 1664T shock shaft will fit that shock too.
Ive got a set of trx1 shocks and have the hardend front shafts but need the rear shafts as the standard shafts 2764 are like putty. Need a bit more strength as I cant afford to lose more races due to someone hitting me from behind.
Sponser links below
Sponser links below
- TRX-1-3
- Has thanked: 2066 times
- Been thanked: 992 times
You need the 2765T shafts. X-long, hardened steel, Ti nitride coated.
Mark
Mark
Thanks Mark.
Sponser links below
Sponser links below
- 2176 Views
Last post by DACECOLI
- 21 Replies
- 3401 Views
Last post by Supernaut
- 1087 Views
Last post by Bullfrog
- 1438 Views
- 769 Views
Last post by UltraHIVE
- 929 Views
Last post by a01butal
- 532 Views
Last post by THUNDERSTRIKE1
- 57 Replies
- 8413 Views
Last post by Lavigna
