Question on Works 91 rear arms for Yok 870C
slazzaro
Has thanked: 6 times
Been thanked: 6 times
Post by slazzaro »
Hi all!!
I have the Works 91 rear arms, the original rear swaybar.. and I'm trying to figure how to connect the swaybat to the arm. :?
Infact in those arms there is not the classic front vertical flat side in which to drill a hole for the ball link.
Do any of you have those arms installed with the swaybar on?
Please help, a picture would be great!!
Thanks, bye :wink:
Kyosho Turbo Optima, Optima MID Custom Special, Optima MID Custom Special truck converted
Yokomo YR4 PRO, YZ-870C
Associated TC4, B3 (x2), B4.1 worlds, C4.2, B42, B44, B6.2, B6.2d, B64
Losi XXXT MF2
Tamiya M05
..more in the past, more in the future..
Dual
Has thanked: 131 times
Been thanked: 40 times
Re: Question on Works 91 rear arms for Yok 870C
Post by Dual »
Hi Slazzaro,
Although identical in design to the Works '93 arms, the Works '91 arms did not come with holes drilled for the swaybar.
Even though the surface of the arms is not flat, it is still possible to drill a hole on each arm for the sway bar (as per the Works '93 arms).
Unless someone beats me to it, I will try to provide some photos later on.
Vin
slazzaro
Post by slazzaro »
This would be very helpful!!
Thanks! :mrgreen:
Losi XXXT MF2
Tamiya M05
slazzaro
Post by slazzaro »
Have You got the chance to take that picture? :?:
Does anyone have advices on how to install the swaybar on those arms?
Merry Christmas to everybody!!! :mrgreen:
Losi XXXT MF2
Tamiya M05
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
slazzaro wrote:Have You got the chance to take that picture? :?:
I'm only 5 years + late, but here is the difference between the 91 works suspension arms without the sway bar mount hole and the 93 works with the hole. :o
a01butal
Has thanked: 34 times
Post by a01butal »
Better late than never! :)
This is all very interesting!
Return to “Yokomo Forum”
