Question on XX verus XXX rear bulkhead and arms
sgirouard
Post by sgirouard »
Will the XX-CR rear bulkhead mount up to a XXX? Are the holes the same etc?
Has thanked: 359 times
Been thanked: 470 times
Re: Question on XX verus XXX rear bulkhead and arms
Nope, they are 100% different-
jamin
Been thanked: 28 times
Post by jamin »
sgirouard wrote:Will the XX-CR rear bulkhead mount up to a XXX? Are the holes the same etc?
You can mount a whole XXX transmission, pivot block and shock tower on a XX chassis, so I am guessing that you should be able to go the other way, as long as you use the whole trasnmission etc. But you certainly couldnt just use the XX bulkhead on its own...
Mad Racer
Post by Mad Racer »
That's right Jamin.
I did it to my XX back than. Brian Kinwald used the XX platform as the test mule for the new tranny.
The bulkheads aren't interchangeable though.
sgirouard
Post by sgirouard »
Thanks for the input everyone. Great info. I've picked up everything I need except for the actual tranny and slipper assembly for a xxx so I'm just gonna do a wait and see on fleabay. I could've stripped down one of my other vehicles to do this but that wasn't a great option.
Return to “Losi Forum”
Users browsing this forum: No User AvatarDotNetDotCom.org [Bot], No User AvatarTbot [Bot] and 7 guests
