What type of a coating is on a RC10t motor plate EPOXY ??
- Regular Member
i want to strip off the coating on a rc10t motor plate (the black plate ) to polish it, nothing i have will strip it, i have tried paint stripper, gasket remove, even a light torching, can,t get it off, does anybody know what it is coated with,, epoxy, hard anodized ?????, so i can get the right stripper, thanks
- Has thanked: 7 times
- Been thanked: 42 times
Re: What type of a coating is on a RC10t motor plate EPOXY ??
It's hard anodized. Over cleaner should do a pretty good job on it, just be sure to read over the list of precautions first
- Regular Member
[quote="adam lancia"]It's hard anodized. Over cleaner should do a pretty good job on it, just be sure to read over the list of precautions first
[ thanks for the info adam, i will give it a try and will post the results
- FasterLouder
- Has thanked: 13 times
- Been thanked: 59 times
I polished the motor plate on my RC10 T2's hard anodised,black motor plate.
I have a drill press with a wire brush wheel in it...2 minutes later,a shiny motor plate!
All The Way Alive
- Regular Member
i used some heavy duty oven cleaner on the motor plate and after a couple of soakings the coating came off with some brushing , thanks everyone for your advice on this, mike
oven cleaner is the way to . helpful hint..... when you apply the oven cleaner rap the part in plastic wrap, it keep the lye based chemicals from evaporating to quickly, and will cut down the the time it takes to strip your parts....good luck
- Has thanked: 183 times
- Been thanked: 157 times
a freezer bag works perfectly for that.racerx350 wrote:oven cleaner is the way to . helpful hint..... when you apply the oven cleaner rap the part in plastic wrap, it keep the lye based chemicals from evaporating to quickly, and will cut down the the time it takes to strip your parts....good luck
and the yellow top easy off is far more effective than the blue.
- 498 Views
Last post by LosiRacer1
- 1048 Views
- 1245 Views
Last post by njdriver04
- 879 Views
Last post by jeepnut24
- 615 Views
- 953 Views
Last post by clinehobbies
- 979 Views
Last post by NCOHOG
- 1028 Views
Users browsing this forum: No registered users and 14 guests
