2.25 motor plate
General info, Q&A.
DMAT
2.25 motor plate
Post by DMAT »
are there any newer motor plates that are compatible with the 2.25?
I'd really like to keep my original motor plates un modified b/c their finish is still fairly good.
If not, can you still run a stealth properly with only the 3 mounting points and the 4th screw shortened so that it doesnt go all the way through sort of like the 6 gear?
Re: 2.25 motor plate
DMAT wrote:are there any newer motor plates that are compatible with the 2.25?
directly? no.
just leave the 4th spacer out and use a shorter screw with a nut between the case and plate.
DMAT
Post by DMAT »
and another reason added to want chris to make some motor plates for that stealth tranny.
unless he'd stamp them out of aluminum with the chassis brace like factory, it's a waste of time in my opinion.
original motor plates are not that hard to find.
DMAT
Post by DMAT »
Kranzels has them too.
I guess my answer shouldve been yes there is. Better suited for a graphite chassis or mid setup though.
Users browsing this forum: No User AvatarMojeek [Bot] and 4 guests
