Novak receiver restoration
Dr. Robotnik
Post by Dr. Robotnik »
Hi guys,
I have a nice working NER2X Novak receiver but the black tap that seals the case is gone. Does anyone know what it was and where to get some?
Cheers
Ed
P.S. This might be in the wrong place as the forum has just changed... :?
GJW
Re: Novak receiver restoration
Post by GJW »
yeah ed im after some of that tape as well great minds think a like hey :wink:
Been thanked: 1319 times
use some 1/4" black pin stripping, or cut some black elecrical tape into a 1/4" strip.
Dr. Robotnik
scr8p wrote:use some 1/4" black pin stripping, or cut some black elecrical tape into a 1/4" strip.
Yes I thought that might work, but is that what it was?
The old stuff seemed to have shrunk into and filled the gaps between the two receiver halves. I don't know, will electrical tape do that?
Bongo Fury
Post by Bongo Fury »
Dr. Robotnik wrote:The old stuff seemed to have shrunk into and filled the gaps between the two receiver halves. I don't know, will electrical tape do that?
A section of large shrink wrap???
GJW
Post by GJW »
the novak tape (comes on 2s recievers and novak 1 esc's) is textured like the tekin stuff am i wrong, there is a rubber seal in between the 2 case halfs on the later esc's..
Dr. Robotnik
Hmm, well if there was a rubber seal then mine is gone... I might just wrap it in electrical tape and call it a day.
BTW bongo, shrink wrap won't work as you need to cut it to fit the crystal in the receiver so it won't stick to the case.
Mr. ED
Has thanked: 62 times
Been thanked: 62 times
Post by Mr. ED »
I've bought this type texture vinyl tape long ago, Ithink it was specially resistant ot water and could be used to seal leaking tubes etc. The width was far off, but with the woven texture it was easy to tear at a constant width. DIY stores are your best bet
Halgar
Has thanked: 146 times
Been thanked: 200 times
Post by Halgar »
I'd give Charlie over at Novak an email. He could tell you what it is, might even have some he'd send you if you asked real nice. Always had good interactions with him.
Dr. Robotnik
Charlie@teamnovak wrote:There was no "seal" inside the case, it was just some simple black tape around the outside of the case.
You can use just about any type of tape. I like to use normal Black
Electrical tape as it is wider.
Cheers for that Halgar (and Charlie obviously) :wink: .
Halgar
Post by Halgar »
No problem Doc. Glad to have helped.
