Old Novak receiver
- radioactivity
- Has thanked: 384 times
- Been thanked: 618 times
Old Novak receiver
I thought I might try to re-create the original label but can't seem to find any images.
I'd also like to see if it still functions.
This was my first receiver from my RC10.
Any help would be appreciated!
Chuck
Chuck
- Has thanked: 1129 times
- Been thanked: 3919 times
Re: Old Novak receiver
Unless that photo is scrunched, it appears to be one of their early aircraft receivers. I don’t think they had labels
They call the NER-2S their first cat/boat receiver. Weird that yours is clearly a 2 channel. Hmm
I have one of these receivers also. I've always called it a NER-2, but never seen any documentation. It's the same size as the old aircraft receivers (bottom half of the case is interchangeable), but it's a purpose built 2 channel.
- Basher67
- Has thanked: 44 times
- Been thanked: 160 times
I also believe that was an aircraft receiver. There were plenty of 2 channel aircraft radios---mostly used in gliders. As far as I remember, and the Novak timeline would verify, the NER-2S was the first land frequency receiver and the design and shape stayed pretty much the same. Even the bigger 3 channel car receivers were still a small square. It was not uncommon for most of us, on little to no budget bitd, to "illegally" re purpose whatever radio we had laying around-----including aircraft radios. I remember using my futaba attack 4 system in my lunchbox. Not allowed at the track, but the radio police never showed up to bust me in my back yard. The frequency of the receiver should give you the answer.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
'82 Brochure/Catalog in the Scans Archive with that receiver in it.
https://www.rc10talk.com/viewtopic.php?f=82&t=6525
- radioactivity
Thanks for all the replies.
Phin I think you nailed it. Mystery solved.
I honestly searched for quite a while and could not find it
It appears as the "2 channel receiver" is the match. The price list also shows a ner 2 (no 'S) . That must be the part's name.
So BradS you were also correct.
All my crystals are 27 mhz for my ner 2s and the ner 2 so that also fits the picture.
I guess I won't be recreating a label when one never existed. It's back in the box it was in for now.
Thanks again to all Chuck
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
Yep, I think it was an airplane receiver also, here's mine along with it's Kraft brother from another mother.
Looked a little deeper in my Novak box and found this one which is definately airplane.
This is all very interesting!
- Been thanked: 100 times
Just found this topic.
Great receivers Alan. I knew there was a Kraft like this but never have seen one before.
For the Novak 2 channel I was searching such receiver for a repro project. But never found one so the project was not started.
- 1663 Views
Last post by Halgar
- 948 Views
Last post by sandkil
- 978 Views
- 166 Views
Last post by morrisey0
- 824 Views
Last post by camlchris
- 2334 Views
Last post by teman
- 836 Views
Last post by Frankentruck
- 1004 Views
Last post by R Cane
