Aluminium parts : removing anodisation and powdercoating
General info, Q&A.
utieh
Has thanked: 4 times
Post by utieh »
I d like for a new project to have polished alunimium parts on my RC10 ( front plate, motor plate )
those parts came anodised or powdercoated.
What tool should I use to remove the powdercoating and to polish the plates, I only own a cheap Dremel.
I know that i must use ovencleaner to remove anodisation but I will have to polish it after too.
Thanks a lot.
Gilles
mikedealer
Re: Aluminium parts : removing anodisation and powdercoating
Post by mikedealer »
you can polish with a dremel, but you might "cut" the metal and create warps and indents, its a timely process too. i recommend this buffer from harbor freight for $50. I recommend some 500-1200 grit sandpaper too from harborfrieght (its cheap) to sand those really tough anodized peices that wont remove even with yellow easy off over cleaner
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=94393
i use the same one, buffing wheels and compound are cheap and sold at harbor freight. The machine doesnt have a lot of "torque", but for buffing aluminum you shouldnt need it, works perfect and ive polished all my aluminum with it..
for a dremel, pick up some of these from ebay, DONT blow money on dremel branded ones cause the price will bankrupt you
http://cgi.ebay.com/36-PCS-POLISHING-BUFFING-WHEELS-FOR-DREMEL-MC19-NEW_W0QQitemZ120148643610QQcmdZViewItem?hash=item120148643610&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
http://cgi.ebay.com/36-PCS-POLISHING-BUFFING-WHEELS-FOR-DREMEL-MC10-NEW_W0QQitemZ120148642493QQcmdZViewItem?hash=item120148642493&_trkparms=72%3A552%7C39%3A1%7C66%3A2%7C65%3A12%7C240%3A1318&_trksid=p3286.c0.m14
utieh
Post by utieh »
Thanks a lot, it helped a lot, I think I will go for the Dremel even if they are tiny, I already have one which is not in a really good condition but I ll make some tests.
Thanks again :)
badhoopty
Has thanked: 183 times
Been thanked: 157 times
Post by badhoopty »
loctite gasket remover (in the spray can) for removing powdercoat. i've read that a good paint stripper will work too.
utieh
Post by utieh »
i ve just removed the powdercoating with some sand paper, I think it was just paint actually cos the previous owner didn t strip the anodising before painting it.
I ll by oven cleaner tomorrow to remove the anodizing and then will polish the parts
Thanks again for your help
Gilles
