Removing paint from anodized parts
Dr. Robotnik
Post by Dr. Robotnik »
Hi guys,
Has this been covered before? I think so but can't find the thread. I remember someone had a chassis covered in paint and managed to remove the paint without damaging the anodizing.
I would like to do the same and was wondering what the best product to use is?
Is it;
Thinners
Alcohol
Nitro fuel
I am based in the UK so if there are any brand names from the UK users that'd be great too.
Thanks in advance for your help :-)
Cheers
Ed
MelvinsArmy
Been thanked: 11 times
Post by MelvinsArmy »
I would think brake fluid would be able to take the paint off without hurting the annodizing, but I'm not 100% sure. I've used brake fluid to strip plenty of hard bodies and model parts. I'd try a test piece, maybe paint a junk annodized part and see if it works on it.
Halgar
Has thanked: 146 times
Been thanked: 197 times
Post by Halgar »
MelvinsArmy wrote:I would think brake fluid would be able to take the paint off without hurting the annodizing, but I'm not 100% sure. I've used brake fluid to strip plenty of hard bodies and model parts. I'd try a test piece, maybe paint a junk annodized part and see if it works on it.
This was going to be my suggestion as well. I've never tried BF on anodized parts, but I would think that it would be fine.
Dr. Robotnik
Ok. The test piece is a good idea. I am pretty sure that brake fluid wasn't what was used before but might give it a go if no one has any other suggestions. Though I'd have to source some brake fluid....
MelvinsArmy
Any auto parts supply store will have it.
Halgar
Post by Halgar »
Just go across the street to the neighbor you don't like and tap their brake line ... :shock: :shock:
J/K :P :P
i used paint reducer that i have at work to take the paint off these parts. there is some discoloration on the tub, but i don't know if it was like that before it was painted.
Dr. Robotnik
Thanks guys I'll look into all those things. I had been using an oven cleaner for the shock towers and plastic parts but it'd be good to have a product that does everything including aluminium.
