mounting wing on rear shock tower?
i've seen some pics where the rear wing is mounted on the shock tower instead of using the aluminum tubes. the metal wire from the wing is put into a small metal piece that screwed into one of the shock mounts and held in place by a little set screw. this look really good b/c the wing doesn't have to be removed to take the body off. where can i get some of those wing mounts?
- bscotti
Re: mounting wing on rear shock tower?
The old school parts were Bud's Bullet Mounts and Yokomo wing mounts, both of which are kinda tough to find. Trinity makes something similar and is available through Tower Hobby or you can make something similar with Aluminum tube stock.
Trinity part ...
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXKA33&P=7
Trinity part ...
Classics rule, moderns drool
- a01butal
- Has thanked: 34 times
- Been thanked: 40 times
This is the BRP bullet wing mounts as I have been schooled. I think there might be 1 set left - may be worth a try anyway.
http://www.greathobbies.com/productinfo/?prod_id=BRP5245
This is all very interesting!
- call-911
Yes, it's a great way to mount your rear wing. The set screws clamp down the wire so you can flip the car and it won't alter the rear wing any. It's much more of a robust way to mount a rear wing.
Keith C
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
Tecnacraft also made a quick release set
They would be very hard to find though
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
Trinity also made some, and I think GPM still makes some.
thanks for the info. i'm placing an order w/ towerhobbies soon so the trinity one's would be good, too bad they're purple.
- call-911
soak 'em in EasyOff oven cleaner... Is that still the trick to remove anodizing?
Keith C
- 1062 Views
- 37 Replies
- 13226 Views
Last post by jaro
- 635 Views
Last post by teman
- 1812 Views
Last post by broodenburg
- 23 Replies
- 3256 Views
Last post by HKS_TRD
- 661 Views
- 944 Views
Last post by USA-1
- 480 Views
Last post by bearrickster
