XX rear shock tower
DHC6
XX rear shock tower
Post by DHC6 »
Just wondering if any one knows if you can fit the XXCR rear shock tower/wing mount to a standard XX? It's getting harder to find wing wires for the XX (still have a few left), and the XXCR shock tower/wing mount is a more modern style with body clips rather then the wire. For future racing it would be nice to have something a little newer in case the original breaks and then I am stuck.
Once you have tasted flight, you will forever walk the earth with your eyes turned skyward, for there you have been, and there you will always long to return - Leonardo da Vinci
bearrickster
Re: XX rear shock tower
Post by bearrickster »
the xxcr still uses the wire the xxx uses mounts? no you cant cross the xxx and xx towers
LOSI RULES!!
Bearrickster's Rides
DHC6
Post by DHC6 »
Bearrickster,
That's what I though as wel until I came across this, have a look at this on the bay
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=230431273138&ssPageName=STRK:MEWAX:IT
Looks like a XX with wing mounts with body clips rather then the wire. After I saw this I thought all the XXCR's were like this. Maybe this is some kind of one off mod? What do you guys think?
bearrickster
Well I just went and looked at my 2 XXcr's and ther is a flat spot on the tower, you could drill it for the xx4 ming mounts like that person did. it should work just fine. I almost did that to mine but their are not predrilled holes in the xx towers.
LOSI RULES!!
Return to “Losi Forum”
Users browsing this forum: User avatarcarloco8 and 2 guests
