RC10GT Pull Start Replacement
jackdc100
Has thanked: 18 times
Post by jackdc100 »
The string for my 90s RC10GT pull start broke. What part do I get to fix it? It it easiest to just replace the whole assembly? It had a mid-90s Dynamite .12PD engine in it.
rctenracer
Been thanked: 81 times
Re: RC10GT Pull Start Replacement
Post by rctenracer »
if the spring is not broken you can rewind it. This may work also.
https://www.horizonhobby.com/product/pull-starter-complete12s12spd15s/DYN6535.html
jackdc100
Post by jackdc100 »
Oh nice :) Thank you. Just the string is broken. I guess I was hoping to replace just that. I am not sure if that is a realistic option though. I know these can be a real hassle to fix if only one part is broken. I also need an o-ring that goes inside the high speed needle. The old one was toast. I don't know if you guys know what size will fit in there. It Is the o ring that goes inside this: https://www.ebay.com/itm/174839175156
jackdc100
Post by jackdc100 »
Will something like this work? https://www.amazon.com/Dynamite-String-Pull-Start-DYN6230/dp/B0006O5212. It doesn't look too bad to repair just the string from what I am seeing on YouTube.
Edit: for some reason it won't let me paste the link. It is for a generic Dynamite pull start string part number DYN6230.
Lowgear
Has thanked: 121 times
Been thanked: 792 times
Post by Lowgear »
I fixed the link for you. That's weird that Amazon links don't work unless they're wrapped in the URL tags. They must be blocking them otherwise.
jackdc100
Post by jackdc100 »
Lowgear wrote: Thu Apr 17, 2025 12:48 am I fixed the link for you. That's weird that Amazon links don't work unless they're wrapped in the URL tags. They must be blocking them otherwise.
Thank you!
Return to “RC10 Truck Forum”
Users browsing this forum: No User AvatarBing [Bot] and 1 guest
