Rc10gt roto start or equivalent?
Weasel4ami
Post by Weasel4ami »
Hi im looking to see if I can put a roto start on my ae .15 pull start gt. Can or is it possible? If so can u suggest a part number? Also what about team associated pro srart?
Weasel4ami
Re: Rc10gt roto start or equivalent?
Sorry to ask these questions guys. My local hobby shop sucks and I only have one where I live. They just don't know. They only sell parts... so n e help would greatly be helpfully. Thanx again for ur time.
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
Rotostart is fairly easy to improvise if you have a cordless drill.
You pull off the pullstart housing leaving just the back plate with the shaft sticking out of the back of your engine
then you take the one way bearing out of your pullstart or get a new one
you find a small socket (1/4 inch drive works best) that the one way bearing fits into, you might need a wrap of electrical tape around the hex to get it to fit snugly into the socket.
then you take an extension that gets the end of it far enough away from the motor to use the drill
finally you get a 1/4 inch drive bit and chuck it into a cordless drill.
Make sure the drill spins the correct direction and you are set :)
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
RC10th
Has thanked: 52 times
Been thanked: 1548 times
Post by RC10th »
HG used to make a rotostart shaft to fit a drill. If you can find one they are easy to use.
Sullivan Tiger Drive is another option.
http://sullivanproducts.com/TigerDriveMainFrame.htm
Return to “RC10 Truck Forum”
