Kyosho Nitro Blizzard
- Dangeruss
- Has thanked: 425 times
- Been thanked: 1408 times
In 1998 Kyosho released a new version of their 1/12 tracked vehicle, the Nitro Blizzard. Originally introduced in 1982 and preceded by four iterations of advancing refinement the Nitro Blizzard would be the first to receive a gas powerplant. Sharing only its tracks with the first Kyosho Blizzard the Nitro rode on an entirely new stamped aluminum chassis with aluminum side plates to hold the torsion spring suspension. A pinion and spur primary drive connected to the two-speed transmission that utilized Kyosho's QRC (Quick Reversing Clutch) technology. A throttle servo actuated linkage slid a clutch disk between two gearsets (forward and reverse) allowing the 'Blizzard to switch between forward and reverse with a simple push or pull of the transmitters trigger. High gear in the two-speed transmission was engaged by an adjustable centrifugal clutch allowing the speed at which gear changes occurred to be tuned as desired. Steering was handled by two linkages running from the rear mounted servo to a pair of disk brakes, one mounted on each side of the plastic drive axle, itself containing a bevel gear differential inside a sealed gearcase. As the servo rotated the linkage would apply the brake to that side, slowing the track and allowing the vehicle to turn. Those rubberized plastic tracks were supported by ten aluminized plastic wheels, four road wheels and one chain tension adjusted drive wheel per side. A two-piece clear lexan Snow Cat style body covered the fan cooled, pull start GS-11X engine, muffler and flip top fuel tank in the almost ready to run kit, sold less radio:
- coxbros1
- Has thanked: 2758 times
- Been thanked: 2407 times
Re: Kyosho Nitro Blizzard
Killer writeup!...Nitro Blizzard is at the top because if it's cool mechanical features..still hunting one to this day
- Has thanked: 1153 times
- Been thanked: 624 times
Another great writeup! I love these Nitro/EV (single 540) Blizzards with the the skid steer braking.. Blizzard EV, DF-300 GP & EP are next on your list sir!
-Brad
- Dangeruss
Thanks ya'll. Awesome kit indeed, a nitro engine tearing across some fresh powder, that's the sound of fun... but imagine a group of these cranking around a snow-covered off-road track.
Blizzard EV comes in a couple days, but the DF-300 is post Y2K so that one'll have to remain a memory.
- 429 Views
Last post by Dangeruss
- 1531 Views
Last post by Nouseforaname
- 950 Views
- 1939 Views
Last post by Hcp22
- 1603 Views
Last post by Eddie234
- 486 Views
- 3051 Views
Last post by hugger19
- 2192 Views
