Ballcups for 5.5mm studs
Forum rules
JosephS
Has thanked: 1243 times
Been thanked: 639 times
Post by JosephS »
I'm interested in using some modern AE 5.5mm ball-studs. They are easy enough to find, however I don't see ballcups like I do for the vintage sizes.
Does anyone make aftermarket rod ends for 5.5 mm?
1911Colt
Has thanked: 1782 times
Been thanked: 859 times
Re: Ballcups for 5.5mm studs
Post by 1911Colt »
I know Schumacher has more, I only found this one that specifically calls out 5.5mm:
1911Colt
Post by 1911Colt »
Found another:
carloco8
Has thanked: 74 times
Been thanked: 271 times
Post by carloco8 »
You can use the RC10 B6 ball cups. They have a longer shank, but you can mark them and cut them down to the same length as original rc10 ball cups with a dremel, or if you happen to have misc. short turnbuckles, leave the ball cups long. #ASC91722
